Setting timing on SOHC D(15) series
Old Oct 14, 2002 | 01:00 PM
madhatter's Avatar
From: boldly scornful of higher mental function, US
Default Setting timing on SOHC D(15) series
The shop manual has me removing the vacuum advance lines from the distributor and plugging them before setting the timing. Upon doing this, the timing marks are approx. 1/4 of the rotation of the crank pulley off of the TDC mark. With the vacuum advance lines plugged into the distributor (connected), the timing marks are on the TDC mark. Which is correct? The car runs fine with the settings from having the vacuum advance plugged in, and I am doubtful I can advance it enough to get the marks to match up without them plugged in (or that that would be wise- they are really far off.) TIA.
-Chris, who read the intructions for once, and is now confused.
mhewitt
Jan 28, 2011 08:23 AM
krysted9354
Feb 5, 2009 06:35 AM
97gsrki
Nov 15, 2007 11:31 AM
dr_latino999
Dec 13, 2004 02:05 PM
rasta420
Jan 5, 2003 08:14 PM
