Running no oil pressure switch ok?
Old Jun 14, 2012 | 07:23 AM
EJ8Squad919's Avatar
Default Running no oil pressure switch ok?
Im done with my ls vtec build and on my golden eagle sandwich plate there is only 2 ports one for the oil feed to the head and im boosted so the oil feed for the turbo. I have a greddy oil pressure gauge. Is it ok to remove the oil pressure switch and put my sending unit there instead?
Old Jun 14, 2012 | 07:25 AM
rich7777's Avatar
Default Re: Running no oil pressure switch ok?
Yeah, providing the thread is the same. I'd rather a actual gauge than a light what comes on when it's to late...
Old Jun 14, 2012 | 08:46 AM
Ok cool it wont throw no code will it? and do i just leave the wire hanging or black tape it so it doesnt get no contact?
Old Jun 14, 2012 | 08:58 AM
Muckman's Avatar
Moderator in Chief
Thats where I have my Defi sending unit.
Leave the plug just hanging loose.
No CEL and no oil light will come on.
Old Jun 14, 2012 | 12:38 PM
SO.GA_SI's Avatar
Becareful installing the sending unit. Most sending units are 1/4 NPT. the stock honda sensor 1/4 BPT.
they make an adaptor that screws in the block then the sending unit screws into it.
Old Jun 14, 2012 | 12:46 PM
dpetro1's Avatar
OEM sensor is 1/8 bpt and I believe the Greddy sender has the correct thread and is small enough not to require a remote mount. OP should be good to go.
Old Jun 14, 2012 | 01:03 PM
TheShodan's Avatar
Moderator
Exactly Keep the gauge.
velisma
Jan 30, 2010 08:24 PM
Mr HYDE
Mar 29, 2007 06:02 PM
Rod.
Aug 2, 2004 10:53 AM
yusoslo
Apr 2, 2004 11:47 AM
Lamchop0000
Sep 7, 2002 12:23 PM
