crx w/ b16a swap troubles
Old Jun 13, 2012 | 07:30 PM
KnightsWhoS4yNi's Avatar
Icon3 crx w/ b16a swap troubles
Engine Problems
Car: obd0 91 Crx w/b16a y1 cable trans. engine is completely stock
Symptoms
Overall power restriction
Engine Bog when throttle pressed more than ½
Vtec sputtering/hesitation no pull
takes more throttle than it should to accelerate
no cel
Replaced Parts At Install
Clutch
Spark Plugs
Plug Wires
Dizzy
Replacement Parts After Install
map sensor
o2 Sensor A,B X2
Fuel Pump 190
Intake Air Temp Sensor
Idle Air Control Valve (Cleaned)
High Flow Cat
Exhaust
Air Intake
Throttle Positioning Sensor (Calibrated)
Vacuum Hoses
Knock Sensor
Ignition Coil
Fpr
Test and Services Done
Compression Test
1 185
2 185
3 184
4 185
Leak Down Test
Fuel Injector Cleaning
Valve Adjustment
Continuity Tested Harness
Fuel Pressure gauge reads 40psi
Ignition and Cam timing dead on
Side Notes
Plug wires thicker gauge than stock due to shorting out to valve cover.
Vtec engages no power increase.
o2 wires have been swapped
tps wires have been swapped
Old Jun 13, 2012 | 08:32 PM
civickiller's Avatar
Default Re: crx w/ b16a swap troubles
what ecu?
Old Jun 13, 2012 | 08:47 PM
Pw0 i have tried 3 other pw0 ecus as well
Old Jun 14, 2012 | 12:37 AM
have you shot timing?
Old Jun 14, 2012 | 05:00 AM
I did the timing. Timing is perfect. Dizzy is at 16 btdc and cams,pulley, and timing mark on belt cover all lined up. Cams are both lined up no tooth jumpage. Messed around with the dizzy but no success. Thanks for your help. 211 views but only 3 respones come on somebody has to know something.
Old Jun 14, 2012 | 05:16 AM
HondaPartsHero's Avatar
Technical Hero
Any check engine lights on?
Old Jun 14, 2012 | 05:38 AM
There are times when i downshift into 4th and floor it around 5k it will trigger an cel. As soon as that happened it drove alot better. Gained hp. The cel is for o2 code 1.
Old Jun 14, 2012 | 08:25 AM
unplug o2 and see if it runs better
Old Jun 14, 2012 | 11:22 AM
Yea i did that. Not a difference and also doesnt cause a cel
Old Jun 14, 2012 | 07:58 PM
check tps volts, closed and open
Old Jun 14, 2012 | 08:38 PM
i have already caliberated it properly
Old Jun 14, 2012 | 08:51 PM
hondad6's Avatar
Loose cut crimped wire somewhere. Is the block grounded? If it is not mechanical then it must be electrical. You have covered all of the mechanical side i believe. lots of electrical too i see. Does it idle OK? What plugs are you using? Stupid question fuel filter? Have you tried another dizzy? I know it was changed before but it could be igniter or controller.
Old Jun 14, 2012 | 08:53 PM
A friend in a week or so is going to let me try his injectors and hook up a wideband o2 and try and see if we can figure out if it is a fuel problem.
Old Jun 14, 2012 | 09:32 PM
I soldered and heat shrinked every wire. Went thru and double checked all wires at ecu and traced them to the sensors they are supposed to go to. Block is grounded at valve cover, thermostat, battery to chassis and to trans bracket. Idles good sometimes it will dip up and down if i have my heater on for to long. Platinum Ngk Plugs. Yea fuel filter 3 months old. Yea had my original an bought a new one as well.
Old Jun 25, 2012 | 08:59 PM
Well today my buddy threw a wide band on my car. What he noticed was when i would let off the gas it would go full rich on the Aem meter. But when i when wot it would be around 15-17 and idle at 14-15. When you let off the gas isn't it supposed to go full lean. He thinks it wiring related. He suggests getting a si engine and underdash harness.
Old Sep 22, 2012 | 02:15 PM
Well i finally figured out what the problem was. A buddy was swapping out my resistor box to see if that was the problem and it wasn't but i looked at the wires going into the plug and the male plug wires and female plug wires didn't match up. So i had to wires switched. In a write up it said order didn't matter but that only applies to the red wires must match up to the black wire on resistor box. Yellow must go to the red on the resistor box. Lesson learned the end.
b16a971
Aug 3, 2016 11:40 PM
hondan00b95
Jul 24, 2014 12:57 PM
Mobeious
Dec 31, 2011 11:44 AM
civicef990
Nov 25, 2011 06:53 AM
dhoff024
10
Apr 12, 2010 11:05 AM
