1996 Civic ex/stock d16y8 starting problems
Old Jun 13, 2012 | 05:53 PM
DontTouchMyEj1's Avatar
Default 1996 Civic ex/stock d16y8 starting problems
A friend of mine drove his civic to autozone and when he was about to leave, it failed to start . We first thought it was the battery and jump started it and it ran fine until he decided to turn off his car to put in some gas.... then we push started it and it stayed on but i had to keep my foot on the gas even when we were at a dead stop the entire ride to my casa. Do you guys know what it could be ?
The battery is relocated to the trunk but the fusebox is still in the engine bay.
Old Jun 13, 2012 | 06:02 PM
jbpnoman's Avatar
Default Re: 1996 Civic ex/stock d16y8 starting problems
During this drive, did you have anything drawing power other than the motor? A/C, stereo, headlights, interior lighting, anything?
Old Jun 13, 2012 | 06:07 PM
nope, everything was off . except for the fan which the idiot owner before me wired it to a switch . Also the i noticed the cluster turning on and off .
Old Jun 13, 2012 | 07:09 PM
jdmjackson's Avatar
sounds like it could need an ALT. but check your grounds aswell
Old Jun 15, 2012 | 02:27 AM
it wouldnt be the alternator because the battery stays charged at 13 volts all the time. but it does have starting problems and i am guna take his starter off and get it tested at autozone .
Old Jun 15, 2012 | 12:31 PM
HCivExoo's Avatar
Ensure that you aren't getting a loose or bad ground somewhere. This can cause a lot of the same symptoms that you are describing. Because of the battery location you have to be more conscious of this.
If you can push start it and not start with the key, a simple but overlooked cause could be the clutch safety switch. If the previous owner enjoyed harassing the wiring harness as you described it is possible that this switch could be loosened or wires cut and spliced back together.
hope that helps
Old Jun 15, 2012 | 02:52 PM
im looking into all the grounds right now (cleaning all connections, and upgrading wires)
but im wondering about this "clutch safety switch"... ive never heard of this before.
yes it does, thanks .
Old Jun 17, 2012 | 03:59 AM
HCivExoo's Avatar
The clutch safety switch is a simple switch that is bolted to the pedal assembly. When you push the clutch in and the switch closes the circuit it closes the circuit for the starter signal. A simple device used to make sure you aren't starting the car with it in gear where it is going to lunge forward unknowingly.
Far from a guarantee but worth a shot if you say this previous owner was doing crazy science in the wiring harness.
TNight
12
Apr 21, 2014 04:39 PM
heyitsaej8
Dec 12, 2010 12:39 PM
ashb82
Honda Civic (2001 - 2005)
Nov 17, 2010 03:27 PM
VTecLude1994
Jun 1, 2007 06:15 PM
92EG8
20
Nov 9, 2006 06:09 PM
