B20vtec. piston/wall oil lubrication with aftermarket rods.
Hi.
The b16a2 got the oil squirters and the oil hole in the rod. When building a B20vtec with aftermarket rods like eagle, how will the cylinderwalls and bottom of the piston be lubricated if there are no squirters (b20z) and the eaglerods dont have the "hole". ?
Concidering i will spend some time on the track (not dragracing).
Oh, ok. Because forged components can handle heat better than cast aluminium...
I suppose the crank counterweights helps to throw some oil around too... coming from the rod lubrication.
Thank you!
Thank you!
mario_pic
Mar 15, 2010 01:35 PM
