Fudge...fan not working
Old Oct 14, 2002 | 12:30 PM
SpeedMonkeyRacing's Avatar
Default Fudge...fan not working
Ok..what could be the reason why my fan's not working. I turn on the fan and nothing comes out and when i turn on ac..I know the ac's on but the fan's not blowing. anybody know the reason why?
Jeff-
Old Oct 14, 2002 | 12:41 PM
STK B16's Avatar
Default Re: Fudge...fan not working (Corporal-Jeff)
check the thermostat see if its hookedup. make sure the wires are hooked up.. if not then manually hook it up to a switch to activate it.
Old Oct 14, 2002 | 05:55 PM
Redline130's Avatar
Fuses?
Old Oct 14, 2002 | 06:35 PM
MrTodd's Avatar
Jeff-
Your talking about the fan inside of the car right? Not the radiator fan?
I think there is some resistor that is attached to the blower motor housing that causes this... I've seen it before but I can't remember exactly which part it is.
You could pull out the HVAC controls, and check the wiring harnesses there, then pull out the blower motor & housing components - just play around with those a bit, make sure there aren't any loose electric connections.
Other than a wiring problem, either the HVAC is bad (heater ventalation air controls - something like that) or that resistor thing is burned out.
g4384063
22
May 16, 2019 09:10 AM
DrewBrews
Dec 23, 2011 09:59 PM
grey_ghost
Jan 31, 2008 12:32 PM
Finest
Jul 25, 2002 05:23 PM
hybrider
Jul 23, 2002 08:21 AM
