HELP with 89 Civic Si B18b1 swap!!!
Old Jun 12, 2012 | 10:44 AM
joshd_bh's Avatar
Icon2 HELP with 89 Civic Si B18b1 swap!!!
I have a 89 Civic Si and the motor recently died after a long problematic existence. I am looking at getting a B18b1 ls swap from a 96 Integra. I think im going to buy new B series axles, motor mounts, and shift linkage from hasport. I understand that it is an OBD2 motor, but I have no idea how I am going to wire it or whatever. I need to know what else I will need to make it work.
The swap includes (and all is from a 96 Integra):
  • B18b1 engine
  • Axles
  • ECU
  • OEM tranny
  • Motor mounts
  • Shift linkage
THERE IS NO HARNESS INCLUDED
Old Jun 12, 2012 | 10:49 AM
91EFH22's Avatar
Default Re: HELP with 89 Civic Si B18b1 swap!!!
Use your stock harness and adapt it to the distributor plugs then the rest is cake.
Old Jun 12, 2012 | 06:52 PM
joshd_bh's Avatar
How do I modify the stock harness?
Old Jun 12, 2012 | 07:22 PM
delsol92's Avatar
just get an obd0 distributor and injectors
Old Jun 12, 2012 | 08:58 PM
crx_si-r's Avatar
Take out the old motor. Put the old parts (ecu, distributor) onto the b18b and your done. You will only need to modify the fan switch since it will now be located on the thermostat housing and not the back of the block
Old Jun 12, 2012 | 10:35 PM
rd91sib18c5r's Avatar
My car is running obd2, I have the rywire jumper and dizzy jumper works great.
Also ran a ls motor on the si ecu dizzy and injectors from the origonal d16 ran fine
passed DEQ, either way works.
Old Jun 13, 2012 | 11:56 AM
Fittest224's Avatar
Let us know witch way you go and what you do... There's a thread witch shows you how to convert the harness I'm doing the same but I'm not gona start till I hav the tranny and axels cuz the rest is all about being patient
Old Jun 13, 2012 | 03:18 PM
villc713's Avatar
No need for modification to the as to you have a mpfi Si civic. Take old motor out with harness and then plug every wire on harness to new motor keep the firewall map sensor, get you a ls dizzy obd1 or obd0 and get you a ls ecu phearble.net is your friend they sell any extra adapter harness' if you go obd1 and a jumper harness for obd1 ecu. You need to extend a couple wires and install motor. Obd1 injectors from junk yard with pins and use the search bar at the top there are plenty of write ups for this swap. O and if you can a wagon traction bar to clear your headers or you will be cutting.
Old Jun 13, 2012 | 07:06 PM
joshd_bh's Avatar
Is this what you're using? http://www.rywire.com/catalog/obd0-m...kage-p-69.html
Would you have a link to this thread? I have found ones that go over the OBD1 ls swap, but not OBD2.
Old Jun 13, 2012 | 10:16 PM
Yep thats the kit plug and play. lol
Old Jun 14, 2012 | 06:02 AM
villc713's Avatar
Don't do obd2 go obd1. Get obd1 dizzy and some obd1 injectors with the pig tails from local pick and pull most of the time they are free......lol......order the obd0-obd1 dizzy plugs (I usually make mines) wire in the injectors wire for wire and order a phearable.net po5 with a obd0-obd1 jumper harness.....and go run a couple cars on the weekend!
Old Jun 14, 2012 | 07:32 AM
firmefaces's Avatar
i dont know if u need parts but i have ls intake manifold ls dizzy obd1 hasport linkage hasport mounts haft shaft axel obd1ecu
hmu if interested
Old Jun 14, 2012 | 08:49 AM
joshd_bh's Avatar
And you use a OBD1 ECU?
Old Jun 14, 2012 | 09:36 AM
villc713's Avatar
Phearable.net
Chipped po5 obd1 ecu
Old Jun 14, 2012 | 10:29 AM
shiroun's Avatar
Hey josh. Take it from me. You're going to need a camber kit aswell for the front. The spindles are longer, causing positive camber by about 1.5 degrees
Old Jun 14, 2012 | 09:53 PM
No i'm running obd2a jdm typre r ecu.
Old Jun 16, 2012 | 06:09 PM
joshd_bh's Avatar
How would this effect my camber? What does it come out looking like?
And I think i have everything planned out. Tell me if I'm missing anything.
- Full B18b1 with stock tranny or B16 tranny
-Hasport axles, motor mounts, shift linkage, and cable to hydro tranny conversion
-Rywire conversion kit stuff
-Phearable.net OBD1 ECU chipped w/ Neptune
-Some professional tuning to make it work right
Old Jun 16, 2012 | 06:21 PM
91EFH22's Avatar
Camber kits are not needed. Its been discussed, theres a thread started here somewhere regarding camber kits being a gimmick
Old Jun 16, 2012 | 08:14 PM
villc713's Avatar
Agreed if your wheels are looking cambered chances are your upper and lower balljoints need fixed and an alignment helps also.
Old Jun 20, 2012 | 09:15 AM
joshd_bh's Avatar
So I got the swap but he couldn't find the oem ecu.. but gave me what he said was a p28 ecu. I can't use it since its vtec so ill sell it and buy one I can use. What is a good price for one of these?
91c-rex_si
14
Mar 27, 2011 08:07 PM
J4k3
May 7, 2007 08:07 PM
BishopXIII
Dec 20, 2005 06:10 PM
VTEC5656
Aug 5, 2004 03:01 PM
