obd1 harness ??
Just picked up a 95 gsr shell, I'm going to be putting a obd1 b16 in it, the car just needs an engine harness, it has the underdash and everything, so my ? Is what harness can I use ?? It's obd1 gsr vtec, do I have to get that one or can I use an ls harness ?? I wasnt sure if the pin outs where the same any help would be great
You use the harness to match your distributor, alternator, and injectors. You can use an ls harness you'll just have to wire in Vtec.
Try google, it's all over the inter-web.
