ls non vtec build
Old Jun 11, 2012 | 11:08 PM
delsol92's Avatar
Default ls non vtec build
just wanting to see how people feel about a Ls non vtec build cus i know not many people do them in my area
car:
88 honda crx dx
full si harness and dash swap
wheels:
kosei k1 ts 14x6(9.3lbs)
tires:
205-50-14 bfg radials in the front
falken 512 185-60-14 rear
block:
b18b1
fresh 82mm bored
eagle knife edge crank
eagle h beam big bolts rods
gsr main girdle line bored
arp main studs
arp 2000 rod bolts
supertech forged 82mm 12.5:1 pistons
head:
p75 head
crower stainless steel standard valves
crower dual valve springs
crower titanium retainers
crower 403-2 cams
skunk2 cam gears
skunk2 oldschool intake manifold
pnp
3 angle valve job
transmission:
jdm s1 cable
xtd stage 4 clutch kit
xtd 8 pound flywheel
misc:
blue gates timing belt
id 725cc injectors(for e85)
hytech rep tri y header
full 2.5 inch exhaust
hondata s300
i paid 300 bucks for the head and 300 for the block(excluding pistons)
aiming for 180 but not sure if im gonna get that
Old Jun 12, 2012 | 10:52 AM
high_alt_CO's Avatar
Default Re: ls non vtec build
Excited about this! I have the B18B swap. Was thinking GSR head but you may have just inspired me to build the LS. Anyways, go for it!
Is this going to be a build thread?
Old Jun 12, 2012 | 01:04 PM
delsol92's Avatar
i can make it a thread if you want
Old Jun 12, 2012 | 02:16 PM
wreckin-rex91's Avatar
where are the pics?
Old Jun 12, 2012 | 02:19 PM
Oh and B18B FTW! My Rex is rockin 82.5mm 8.5:1 JE pistons, Eagle H-Beams, ARP errything, massaged crank, ACL bearings and a Garrett 57 trim 63A/R. Big bada boom! I assume you will be all motor. Good luck! No VTEC is alright... I will take the monster torque of the B1!
Old Jun 12, 2012 | 03:04 PM
Yeah I'd love to see it. I'm about to start my EF build but can't until I change the head gasket on my RSX this weekend and I lose the whole trial member bs. So, I need some ideas. And I'd love to see where you take it. Not a lot of people do the Non-Vtec build. At least not out here in CO.
Be different and go for it.
Old Jun 12, 2012 | 06:07 PM
delsol92's Avatar
so heres the pics requested
heres the car when i first got it with the a6 in it
i put in a b18a with s1 tranny, it started smokin after 4 months so rebuild
motor has about 900 miles on it now but is about to come out
here it is for first start up after the rebuild
and here is the car how it sits now
as for the mods for future i dont have pics of the block but here is what i have
valve springs and retainers in head
stainless crower valves
skunk2 og intake manny
cams
crower
intake
exhaust
eagle h beams
Old Jun 12, 2012 | 06:10 PM
delsol92's Avatar
im goin for all motor and every once in a while a big boy shot and thanks im hoping i get what im aiming for
Old Jun 13, 2012 | 03:21 AM
villc713's Avatar
Sweet build shoulda went your route when I had my b1 and my a1 instead of Frankenstein ls- v....probably woulda lasted longer too
Old Jun 13, 2012 | 10:07 AM
Very nice setup. The engine bay looks clean already.
Old Jun 13, 2012 | 11:06 AM
TeamRedline89Hatch's Avatar
I would love to put that head on my high comp b20 block.. should be a fun set up, although I can see you having traction issues with no lsd lol
What traction bar will you be running?
Old Jun 13, 2012 | 05:35 PM
delsol92's Avatar
i will be using the traction bar, and i will be getting a factory lsd out of the y1 cable tranny
2n-chilli
11
Apr 15, 2011 07:35 AM
96Spec Ek
62
Sep 9, 2009 08:25 PM
kevb18crx
Jan 18, 2006 08:03 PM
Alpha_GSR
Apr 3, 2002 10:46 AM
