Tranny swap
its not hard. you need the transmission, the mount, rear t bracket, ECU, flywheel (flywheel bolts) (pressure plate bolts), clutch kit, shift linkage, clutch pedal, master cylinder and lines, and slave cylinder. and minimal wiring.
sageuvagony
Mar 28, 2007 09:14 PM
se help Thank you
