Odd shake
Old Jun 11, 2012 | 08:33 AM
FrodeyEJ1's Avatar
Default Odd shake
This is on my 95ex daily driver. When I first got the car and wasn't used to the clutch I would get an odd shake under the hood near stall. I haven't had it do it in months and It happened the other day again. I've tested it with a buddy by near stalling and saw no motor movement. Any ideas? Or other way to test mounts?
Old Jun 11, 2012 | 08:37 AM
JuggerNaut-CTR's Avatar
Default Re: Odd shake
I test mounts by grabbing the intake mainfold and valvecover and yank on the motor.
Shaking can be due to some different things...
-worn mounts
-unbalanced wheel
-bent wheel
-bent axel
-bad bushing somewhere
those mentioned about I have expierenced w/ shaking.
Old Jun 11, 2012 | 08:54 AM
FrodeyEJ1's Avatar
-worn mounts
-unbalanced wheel
-bent wheel
-bent axel
It's more of a motor shake then a tire shake but I'll try moving the motor as mentioned also this only happens when going from a stop into load
Old Jun 11, 2012 | 12:28 PM
Sounds to be your mounts dude
Old Jun 11, 2012 | 12:36 PM
noz79's Avatar
Put the emergency brake up and put it in first, give it a little gas not like your going to race but just gradually making the engine rock a little. Do the same for reverse. You should be able to do it like this with a helper. Whoever is looking at the motor should stand on the side of the car just in case.
boostedvtecB16
Feb 23, 2012 08:08 AM
teddy_dc2
May 2, 2006 10:32 PM
steve96accord
Apr 5, 2006 12:03 AM
CpRiCe87
13
Mar 27, 2006 07:37 PM
SamC
Apr 10, 2002 01:11 PM
