92 civic best 12v location??????
Old Jun 10, 2012 | 09:25 PM
jdm 1080p's Avatar
Icon2 92 civic best 12v location??????
i looking to run a few toggle switches in my car but idk where i should splice the power to and if i would need fuses behind them... i kinda wanted to make a new sub harness that involves multiple gauges and switches... such as radiator fan and cut offs!
anyone have any good detailed blue prints of any toggle diagrams, found a few on Google but haven't seems to work to well
all help is appreciated
Old Jun 10, 2012 | 10:56 PM
jbpnoman's Avatar
Default Re: 92 civic best 12v location??????
Any new wiring you add should be fused as close to the power source as possible, and with the proper amperage for the size wire you're using. You can research fusing wires yourself.
The absolute best place to get a 12V reference line would be straight from the battery. Run a ~6-8g wire into a distribution block/fuse panel, and branch out off that. If you're planning on running a lot of switches, get an under-dash fuse box out of any older car at a scrap yard, hide it somewhere in your car, and repin it for what you want.
Old Jun 12, 2012 | 09:58 AM
jdm 1080p's Avatar
thanks for the help i have another civic fuse box i just gonna be running 3 switch and 4 gauges
switches. heat blower motor, radiator fan, secondary light switch for gauges
gauges. air/fuel, volts, oil pressure, vac/boost
Old Jun 12, 2012 | 10:20 AM
EJ8_Man's Avatar
I ran a 12v amp switch inside of my center console compartment (where the e-brake sits). It is hidden and easily accessible.
To the left and right of the e-brake are plastic covers, I drilled a hole in the drivers side cover and installed my bass volume ****, also very accessible.
Old Jun 14, 2012 | 03:49 PM
jdm 1080p's Avatar
i c im planning on making a secondary fuse box from a old civic one... ill post some pics up sooner or later
Old Jun 15, 2012 | 03:42 AM
jbpnoman's Avatar
7 wires total, using a partial fuse box would be your best bet.
Old Jun 15, 2012 | 04:04 AM
lazlong's Avatar
We use ones similar to this at work:
You run your main power (fused) and ground to it then run your fused circuits from there. It's nice in that you run ground to it then you can ground all your circuits there instead of a bunch of individual grounds.
Old Jun 15, 2012 | 07:41 AM
beecee18's Avatar
Old Jun 25, 2012 | 01:19 AM
jdm 1080p's Avatar
oh thats sweet looking i used a secondary fuse box from a civic works fine but i need to sodder wire together cuz i just have but connectors.. when i hit a bump it shuts off for s second and then comes back on
Old Jun 25, 2012 | 02:05 AM
jbpnoman's Avatar
A proper solder joint and heat shrink will run circles around butt connectors any day of the week when it comes to car wiring.
TooManyHobbies
Sep 22, 2014 05:12 PM
fatsalmon15
Audio / Security / Video
Apr 10, 2014 06:44 AM
starbai
Dec 10, 2008 02:03 PM
Namtab_Reverof
13
Jan 9, 2005 12:42 PM
gsrstyle
Oct 13, 2003 03:42 PM
