Put new distributor in my VX, car nearly stalls after applying gas
Old Jun 10, 2012 | 11:00 AM
PePe240sx's Avatar
Default Put new distributor in my VX, car nearly stalls after applying gas
I ended up getting a new distributor for the D15Z1 since I didn't realize I had warranty on it, so I put that sucker in, started it up last night just to make sure it started, that was a good sign.
But now after letting it get to operating temp, if I put the A/C on or even apply the throttle while in idle, the idle will drop dramatically to the point of where it nearly stalls. Did I set off the timing on the vehicle after swapping distributors out or what?
grumblemarc's Avatar
The Grumpiest
Default Re: Put new distributor in my VX, car nearly stalls after applying gas
Did you time it with a timing light??
Old Jun 10, 2012 | 11:17 AM
PePe240sx's Avatar
I'll be honest, I have no clue how to time the car even with a timing light.
Old Jun 10, 2012 | 11:19 AM
The Grumpiest
Link from the FAQs.
http://www.hondacivicforum.com/forum...ustment-16210/
Old Jun 10, 2012 | 11:47 AM
PePe240sx's Avatar
Thanks!
So this sounds like a timing issue doesn't it?
Old Jun 10, 2012 | 11:50 AM
The Grumpiest
Right now it does.
Old Jun 11, 2012 | 05:16 PM
PePe240sx's Avatar
I think I got it adjusted correctly without a timing light, but the battery light stays on. I'm not sure why.
Old Jun 11, 2012 | 06:01 PM
jbpnoman's Avatar
The battery light stays on because either your system isn't charging correctly, or the ECU thinks your system isn't charging correctly. Make sure you didn't unplug anything at the alternator, and make sure the belt is tight.
Kaminsky
14
Aug 7, 2015 03:03 PM
redm3turbo
Jul 25, 2015 08:34 AM
Kyogie12
Dec 18, 2011 05:48 AM
sythe21
Oct 21, 2011 05:30 PM
philipkrotch
Jan 23, 2003 10:40 AM
