***Diagnosis - Checking tool Vacuum gauge***
Old Jun 9, 2012 | 01:55 PM
hussain-vtec's Avatar
Default ***Diagnosis - Checking tool Vacuum gauge***
HI Guy's.
Thing is very simple an cheap can tel us allot.
A Vacuum gauge, all of you guy's are thinking WTF but believe me its Good tool.
Vacuum gauge - patterns and meaning
A basic vacuum gauge is not expensive and can be extremely useful in analyzing your engine.
The gauge values below are in the standard units of INCHES OF MERCURY.
First, WITH THE ENGINE WARM AND IDLING there are 6 gauge patterns:
1 normal and
5 problem patterns
- worn rings
- stickingvalve
- burnt valve
- leaky valve
- worn valveguide
Next, WITH THE ENGINE WARM, BLIP THE THROTTLE there are 2 gauge patterns:
1 normal and- worn rings or poor oil
Normal IDLE condition: slight fluctuation around some number from 17 to 22.
Problem: IDLE condition: slight fluctuation aroundsome number lower than normal by 4-5 points.
Analysis: Usually worn rings but could also be old engine oil, late ignition timing, a leaky vacuum hose or a leak in the intake system.
Problem: IDLE condition: vacuum drops by 4-5 points occasionally.
Analysis: Usually sticking valve. May also be misfire. Check the color and condition of the spark plugs.
Problem: IDLE condition: vacuum drops by 6-7 points on regular cycle.
Analysis: Usually a burnt valve.
Check the color and condition of the spark plugs. Leak-down test to prove condition.
Problem: IDLE condition: vacuum drops by 5-6 points on regular cycle.
Analysis: Usually a leaky valve. May also be misfire. Check the color and condition of the spark plugs.
Problem: IDLE condition: rapid fluctuation of 3-4points on regular cycle.
Analysis: Usually a worn valveguide. Exhaust maybe smoking be present.
If engine speed changes with the needle, check for leaks inthe intake system.
Normal THROTTLE BLIP condition: rapid fall to 2 on acceleration then over vacuum(25) and return to normal.
Problem: THROTTLE BLIP condition: rapid fall to 0 on acceleration and over vacuum and return to to a lower than normal reading.
Analysis: Usually worn rings or old oil
Old Jun 9, 2012 | 03:21 PM
grumblemarc's Avatar
The Grumpiest
Default Re: ***Diagnosis - Checking tool Vacuum gauge***
http://twrite.org/shogunnew/topmenu.html
Old Jun 9, 2012 | 10:04 PM
Originally Posted by grumblemarc
Yes sir.
What do you think of this is it Good or what, i no this is old school diagnose but it's works fine.
Old Jun 10, 2012 | 03:23 AM
The Grumpiest
Give credit where it is due. If not=plagerism.
Old Jun 10, 2012 | 03:47 AM
EsotericImage's Avatar
Retired Moderator
another method I do is slowly rev a warm engine to 2000 rpms
then let off the gas quickly to snap the throttle plate closed.
you should see 2-6" of vac. Obviously, the more vac, the better.
Little or barely 2" means you have issues.
Old Jun 11, 2012 | 12:43 AM
Thanks for participate, Any other test you have notice & Experienced?
R81DC4
May 22, 2011 06:37 AM
Bambinoh
Dec 12, 2007 07:13 AM
HondaTeg95
Feb 15, 2006 05:24 PM
r7
Sep 20, 2002 07:02 PM
Defiant1999
Jan 5, 2002 07:10 AM
