Need a new clutch/pressure plate setup advice please
Car is in the signature: I bought a cheapo 6 puck stage 3 or 4 whatever eclutchmaster clutch and pressure plate. Im having an issue getting power to the ground under heavy load or maximum power. Rpms Slip and not much movement. Its fine under 5 lbs of boost or less. I was told to look for better clutch setup.
What clutch/pressure plate setup would you guys recommend that will hold the little power im making now, dont plan to move the power up anytime soon.
All I know is you need to get one that is rated to hold the power. All this "stage" stuff can be really confusing. Just check the specs and go from there.
