everyone says no....im thinkin yes
ok, here's the deal, im running eagle rods, j.e. 8.5:1 pistons, 450cc dsm injectors, with a stage 2 revhard kit in a ls motor. i have my stock single core radiator. no headwork done. i have a safc and plan on running the hack. people here are telling me that there is no way i am going to be able to run more than 6lbs of boost. can anyone that has close to the same setup tell me what kinds of boost they are running or can someone tell me what i would have to do to run about 14 lbs of boost? thanks
dave
dave
hmm theres no reason you cant run 14psi on that, ive seen people use fmu to make 350hp before..
i know a guy running 20 on a stock ls motor, but hes got hondata..
https://honda-tech.com/zerothread?id=306215 <--But both cars are running Hondata. YMMV.
is the problem with not enough fuel past 12 psi..or 10, whatever it is? and would a hondata system fix that problem, also, would you recommend bigger injectors for taht?
hondata would let you get rid of the afc and tune with it.. teh reason you cant go past 12 is because the map will go past its voltage limit and it will trip the cel and throw a map sensor code i belive..
[Modified by tygsr, 3:13 AM 10/15/2002]
Guest
Posts: n/a
http://www.angelfire.com/ab7/diymaplimiter
Works on the same principle as the AFC hack or the SMC, $21 Paypal, shipped. You can use it with a 3 bar but let me know that is what you intend to do.
Easy... four wires, tap the MAP sensor +5 volt supply wire, tap the MAP sensor ground wire, cut the signal wire and attach the MAP sensor end to input, ECU end to output.
Whoa wait a second here. Give me some more tech. info about this strange thing you are building.
so you can basically do a voltage clamp on the map and still use your afc to rich/lean out your fuel system without havngto worry aobut it???? what is the max voltage the sensor can see before it throws the cel??
Guest
Posts: n/a
The voltage clamp is for when you want to electronically limit your MAP signal instead of running check valves or a missing link, that's circuit #1, circuit number #2 applies a correction function to the MAP sensor voltage of the form:
f(x) = mx +b where x is the original MAP voltage and f(x) is the corrected MAP voltage.
Markaccord95
Jan 11, 2002 11:34 AM
