93 civic Vx b20 - wobbling noise and vibration when turning left
Old Jun 8, 2012 | 09:03 AM
Jap.Doe's Avatar
Default 93 civic Vx b20 - wobbling noise and vibration when turning left
Like the title says i have a Civic vx with a b20 and a b16 transmission. it makes this weird wobbling noise when i'm driving, and increases in loudness when i turn left but completely vanishes when i turn right, theres also a vibration that accompanies the sound. Any ideas?
Old Jun 8, 2012 | 09:06 AM
kyden's Avatar
Default Re: 93 civic Vx b20, weird noise.
sounds like you have a bad axle or wheel bearing on the right side.
Old Jun 8, 2012 | 01:30 PM
Jap.Doe's Avatar
it sounds like its coming from the driver side though, i took a look and couldnt see anything wrong as far as the suspension, and the wheel was easy enough to turn, i'll check the passenger side later.
Old Jun 8, 2012 | 01:34 PM
thirsk66's Avatar
Agree you need to check your axles and wheel bearings. Also check all of your upper and lower ball joints for play/movement, as well as your tie rods while your in that area
angrysmileyface
Jun 7, 2012 02:11 PM
Ming Tsai
Sep 22, 2006 09:05 AM
philosofy1
Jan 26, 2006 05:44 AM
WhitEdRift
Mar 11, 2004 08:48 PM
