newly rebuilt engine zero compression in 4th cylinder!
Hi guys,
Before I get flamed for not searching before I post I have a reason. This is my daily drive and I need fast answers. I dont have time to look all day for my specific problem to be found.
Here is the problem. Newly rebuilt longblock b18b. Compression is 9.1. Just got it back from the machine shop not to long ago. We finally got it in and did a compression test right away just to see if everything was working well. On the first three cylinders compression was right at like 75 +-. The 4th was zero.... And there is oil in the spark plug. From what searching I have been able to do I see that it could be valves either bent or broken or the piston rings are off...
Any thoughts? Anything would be appreciated.
Thanks
Thanks
goodness HUGE weight off my shoulders!! the valves were just a little to tight so they were not closing all the way. Adjusted the valve lash and its running now! Thanks guys
street dreams
Nov 21, 2004 02:44 PM
