lsvtec wiseco or cp pistons???
Old Jun 7, 2012 | 10:00 PM
carlossolorzano's Avatar
Default lsvtec wiseco or cp pistons???
Need help on my lsvtec turbo set up... i have a b18b1 block micro polish crank 81mm, eagle rods, i just dont know what pistons to use im doing turbo set up... should i use Wiseco pistons or CP pistons, also what crankshaft bearing and rod bearings? what brand
Old Jun 7, 2012 | 10:02 PM
doood's Avatar
been there done that
Default Re: lsvtec wiseco or cp pistons???
both make great pistons. cant go wrong with either. stick with oem bearings if you can.
Old Jun 7, 2012 | 10:14 PM
so they are both good pistons for turbo? oem bearing will work for the rod and crank shaft bearings??
Old Jun 7, 2012 | 10:21 PM
doood's Avatar
didnt i just say that?
Old Jun 7, 2012 | 10:26 PM
yungkhmer's Avatar
aries flat top
Old Jun 7, 2012 | 10:49 PM
KILLAB17VTEC's Avatar
Genetically Gay
JE low Pistons
Old Jun 8, 2012 | 04:10 PM
which ones will be able to handel high rev?
Old Jun 8, 2012 | 04:16 PM
doood's Avatar
pistons are the least of your worries with high revs
Old Jun 8, 2012 | 04:21 PM
mike703's Avatar
dude get what ever forged pistons that have the best deal. in the 4340 flavor. i belive thats the correct metal. the expand less and will last a little longer. the oem crank is fine as well as oem bearings are fine. have you taken you **** to the machine shop yet? if not dont order pistons until you know if you need overbore or not. then order the pistons then get ur **** bored once pistons are in hand.
Old Jun 9, 2012 | 09:49 PM
im going to bord it out to 81.5 or 82 idk yet
Old Jun 9, 2012 | 10:42 PM
doood's Avatar
bore the least amount necessary to freshen the bore
thumper64
Nov 4, 2009 11:58 AM
promotor
May 3, 2009 07:46 PM
PYITR821
Sep 13, 2005 07:33 PM
RHDintegXsi
Mar 11, 2005 06:32 AM
