98 civic ex problem engine shut off
Old Jun 7, 2012 | 03:23 PM
AllAboutHonda's Avatar
Default 98 civic ex problem engine shut off
I'm having problem with my civic doesn't excelerate correctly, it lags and also the engine is very weak. Then when i come go a complete stop at the stop sign. The engine go so weak that it just shut itself off... No Cel is on. Please help, thanks.
Old Jun 7, 2012 | 03:44 PM
Default Re: 98 civic ex problem engine shut off
And also coming to a stop sign will the car is on a complete stop, car is choking, then like i said it just shut off..
Old Jun 7, 2012 | 04:30 PM
It's a D16Y8 stock, the only thing I think it could be is the distributor...
Old Jun 7, 2012 | 04:34 PM
motegicivic's Avatar
Test the coil, there are instructions in the stickies, prob the tec type dizzy.
Could be a timing issue.
When is the last time you did the cap rotor wires and plugs?
Old Jun 7, 2012 | 07:56 PM
Cap, rotor, wires and plugs are all brand new beside the whole disturbutor. Yeah and maybe it could be the coil... I hope thats the problem... would you guys think that could be the problem?
Thanks for the reply
Old Jun 7, 2012 | 07:59 PM
ek9_B18C's Avatar
fuel filter or cloged cat.
Old Jun 7, 2012 | 08:37 PM
Former User's Avatar
Does the CEL work?
Old Jun 7, 2012 | 09:40 PM
Yeah, before cel was o2 sensor... I don't think it could be that cause its a new cat. Header to muffler are all brand new. But again I feel that lag before it was the same lag and not just that the o2 came on when I feel that lag. but now its worst, the car actually die with no check light on.
Old Jun 7, 2012 | 09:51 PM
ek9_B18C's Avatar
well it sounds like you did most of the basic upgrades so i would think fuel, or timing. So when was the last time you adjusted the valves and replace the fuel filter?
Old Jun 7, 2012 | 10:21 PM
jbpnoman's Avatar
Before you buy a replacement fuel filter, borrow/rent a fuel pressure tester, as well as a timing light. Make sure you're getting 37-40PSI as measured at the top of the fuel filter, and make sure your timing is where it should be.
Old Jun 8, 2012 | 04:42 AM
My fuel filter is brand new aswell...
Old Jun 8, 2012 | 04:48 AM
you guys think it could be the fuel pump? hmm I getting a second thought. It might be the fuel pump. because when I step on the gas it blog and lagg as well. To a complete stop it shut down on me, and when I pull over to the side to check my engine I tap on the cable(gas pedal cable). The engine sound really weak, and then back to normal. I don't know, thanks for the reply guys.
Old Jun 8, 2012 | 05:03 AM
Originally Posted by ek9_B18C
...i would think fuel, or timing.
This^
Check the mechanical timing. It may be off by a tooth on the timing belt.
Old Jun 8, 2012 | 09:22 AM
Ron which way would I be turning the crank to check timing? Clockwise or counter clockwise..?
Old Jun 8, 2012 | 10:25 AM
Only counterclockwise; never clockwise
Old Jun 8, 2012 | 11:56 AM
I check timing is not the timing, fuel pump maybe? Or distributor ??
Old Jun 8, 2012 | 02:27 PM
Please read my post 4 again.
Test the coil.......simple to do it, need a multi meter.
If that is not it test the ICM.
Old Jun 11, 2012 | 02:29 PM
I test the coil already not it. What will happen if you use 10w30 oil? And if you were to check your oil dip stick it pass the second dot About 1 inch would that be the problem??
To much oil and to thick of oil what would cause it the cwr to react? Lag? Weak? Choking??
Any idea guys??
Old Jun 11, 2012 | 02:38 PM
noz79's Avatar
With Honda anyway.
Old Jun 11, 2012 | 02:53 PM
4drferio's Avatar
check ur fuel pump!
Old Jun 11, 2012 | 03:09 PM
I just replace my fuel pump, after market welobro 255. It was my brother he didn't want it so i put that in... Still the same. What about the oil, i was talking about would that have any effect?
Old Jun 11, 2012 | 04:41 PM
Honda's do not like Walbro fuel pumps BTW. Can you put a stock one back in?
Not the oil.
Test the ICM.
Old Jun 11, 2012 | 04:56 PM
92bseries's Avatar
if all your fuel options have been crossed off, then its the timing or not enough spark, thats the only 2 things it could be. but to me it sounds like the motor is off time by a tooth or 2
Old Jun 11, 2012 | 06:04 PM
jbpnoman's Avatar
It doesn't matter if parts are brand new - you still need to test them. DOA parts happen.
Fuel pressure test. Timing light.
Old Jun 12, 2012 | 11:32 AM
yeah, I'm gonna put my stock fuel pump back in and if its not the oil then could it be the fuel injector? And btw, my fuel filter is a after market fuel filter. It's a little bigger then the stock fuel filter I have... But when I first put that in, I never had that kinda of problem. So Idk I might not be the fuel filter.
