Issue with b series t bracket
1995 civic eg coupe
ls motor
ls tranny
The t-bracket that i'm using is not quite fiting. Is there a special b seires t-bracket that i need to use. Please let me know asap. Thank you
ls motor
ls tranny
96-00 Civics use a different subframe than the 92-95 civics and 94-01 integras. if your are doing a b swap in a 92-95. you need an integra rear t bracket. if you are doing a b swap in a 96-00 civic then you need the SI t bracket.
I_LuvmyHonda
Sep 24, 2004 01:55 AM
