I need better 3rd gear
Old Oct 14, 2002 | 09:18 AM
senpai's Avatar
Default I need better 3rd gear
Is there a BETTER 3rd gear for us D-series guys. I have a D16y8. The B16 3rd gear is the enemy.
Old Oct 14, 2002 | 09:22 AM
tonyxcom's Avatar
Default Re: I need better 3rd gear (maztur)
look at the EG SI's tranny. I think those are the shortest gears you can get for a D motor in a hydro tranny.
Old Oct 14, 2002 | 09:32 AM
dom93hatch's Avatar
Default Re: I need better 3rd gear (tonyxcom)
Doesn't the 5th gen EX and Si have the same manual tranny?
[Modified by dom93hatch, 10:32 AM 10/14/2002]
Old Oct 14, 2002 | 09:35 AM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Default Re: I need better 3rd gear (dom93hatch)
I don`t think so, but I could be wrong.
Old Oct 14, 2002 | 11:55 AM
hondachick81's Avatar
Default Re: I need better 3rd gear (vtecvoodoo)
"Re: I need better 3rd gear "
....hey, I need torque! ....more low end
Old Oct 14, 2002 | 11:56 AM
SpooN Man's Avatar
Default Re: I need better 3rd gear (civicgirl114)
I think they are the same, or very very close
Old Oct 14, 2002 | 12:01 PM
senpai's Avatar
And this is different from my 6G Ex tranny?
Old Oct 14, 2002 | 12:24 PM
IM ALL BOB's Avatar
check Mista bone's site... http://home.cinci.rr.com/mistab0ne/tranny.html
but when u look at the specs.. comparing to a EJ8 EX tranny..the only main difference is the 5th gear.. the EH si and del sol si tranny have a higher 5th gear
I believe there is only the SRR FDs which are 4.7 and 4.9 and these are possibly the cheapest most effective ways to increase the performance of the car.. but I do not know how reliable the FDs are http://www.srr.com.tw/index2.htm
Old Oct 14, 2002 | 12:51 PM
senpai's Avatar
Default Re: I need better 3rd gear (IM ALL BOB)
I've been there already.
I don't really care for 5th gear. So, basically I'm concerned about the final drive then? Which one gives me better acceleration? I may try the CX/VX 3rd as my 4th too ... but how about 3rd?
[Modified by maztur, 3:54 PM 10/14/2002]
Old Oct 14, 2002 | 01:02 PM
liam821's Avatar
25 Year Member
You best bet is swapping gears out of a ZC tranny. Its going to be the shortest. If you dont want to bother with the work your best bet is the 92-95 SI/EX. The EX has a longer 5th but the rest of the gears are the same as the SI.
liam
Old Oct 14, 2002 | 01:24 PM
IM ALL BOB's Avatar
Default Re: I need better 3rd gear (liam821)
I don't believe there are a ton of sohc hydro ZC trannies lurking around as I assume you can not use the cable gears into the hydro tranny? if I am mistaken please correct me..but best bet would be to swap in a higher FD it will change all the gearing in the tranny though u will lose a tad of top speed .. it's probably worth every penny
92EG8
May 16, 2007 06:46 AM
standaloneaccord
Oct 7, 2005 09:03 AM
whp
Nov 16, 2004 05:16 PM
joestud
Apr 2, 2003 02:24 PM
