New NepTune user, some issues
Old Jun 6, 2012 | 06:13 PM
spAdam's Avatar
Loved
Community Favorite
Default New NepTune user, some issues
I also posted this in the HRTuning forum, hopefully I can get some more input from you guys as well.
Copy/Paste:
Noob here.
I'm having pretty much the same issues as above, so I didn't see the need to start a whole new thread.
Here is where I'm at, and what I have done so far.
- 2000 Civic LX
- Yonaka Adapter harness
- High compression 11.45:1 b20z/p8r head
- P28, demon 1.2
- PLX wideband, wb output pinned to d14
- I've watched the install videos, and confirmed correct installation of the software and demon.
- I removed the board completely from the ecu so that I can see the socket from the side to confirm that the board is connected properly.
- Checked pictures to confirm that the data cable is connected to cn2 correctly.
- Selected an LS basemap
- Defeated H02S1 heater
- selected wb input and fuel parameters per instruction video
- connected to com4
- datalogging and live update on
- selected upload basemap, confirmed update/connect
- red led on with key off, off with key on; green flashes constant
Situation:
- Key on, no data displayed (default values in data pane/gauges blank)
- MIL on. If I depress gas with car not running, MIL goes out and relights as I hit WOT
- No codes displayed in NepTune, if I select clear codes light goes out momentarily (~2-3sec)
- car idles and revs fine, but begins to idle lean as temperature comes up (per PLX gauge)
- car runs/drives fine with PLX narrowband output to d14 and a different chipped ecu
Hopefully thats enough info! Any input?
Also... NepTune doesn't seem to "permanently" install on my computer. Every time I launch I have to agree to the license terms and start everything from scratch. What gives?
SpAdam
Old Jun 6, 2012 | 08:39 PM
HRTuning's Avatar
Default Re: New NepTune user, some issues
You updated your post on the NepTune forum saying that you figured it out. If you have any further questions please post over there.
Efabe
Engine Management and Tuning
Aug 20, 2015 04:51 PM
Sick & Claw
Jan 11, 2015 07:41 AM
highazamotha
Feb 10, 2010 06:30 PM
Darksoul
Nov 3, 2004 11:21 AM
eastbay92cx
Oct 23, 2004 07:23 PM
