Noob question: How do pistons make compression?
I understand what compression is, but when people buy 'High compression' piston, what changes the compression? is it the shape of the piston, length, width??
Thanks
Thanks
Compression is the relationship of the top surface of the piston to the head at bottom dead center and top dead center. It is a direct ratio of how much volume is available when the piston has traveled all the way down, and then how much it has been compressed when all the way up. Pistons, rods, crank,bore, head, and head gasket can all effect the overal compression ratio.
