Is there anyway to check the Lost Motion Assembly?
Old Jun 5, 2012 | 06:35 PM
smb90's Avatar
Default Is there anyway to check the Lost Motion Assembly?
I think I am having an issue with the Lost Motion Assembly. They aren't sticking when they are out, but when the engine cranks a ticking noise is coming from the head. The rocker arm assembly has been completely replaced and the valves have been checked. The only thing I can think of to be the problem is the Lost Motion Assembly.
Old Jun 5, 2012 | 06:51 PM
Former User's Avatar
Default Re: Is there anyway to check the Lost Motion Assembly?
You MUST provide all pertinent information about your car and engine. Failure to do so may result in thread closure.
Old Jun 5, 2012 | 07:03 PM
smb90's Avatar
1993 Honda Civic Del Sol Si
1.6L Engine. Manual Transmission.
D16Z6
Old Jun 5, 2012 | 07:16 PM
luvmihatch's Avatar
Im interested in this also. My Lmas are starting to make a noise My type r just hit 100k.
Old Jun 5, 2012 | 08:15 PM
smb90's Avatar
http://www.youtube.com/watch?v=jW4x-10tz1c
video
Old Jun 7, 2012 | 01:55 AM
vtec-8400rpm's Avatar
no real test to check if they are the source of the noise, unless we could get some sort of medical camera to look inside the engine while its running
when u install them, hold the lma upside down and fill a thick viscoscity oil into the singular hole on the underside until it fills up while blocking the openings at the other end with your fingers. Then, quickly install them in its (lubricated)cavity. if u install them without filling them with oil there is an audible difference.
running performance cams will generally result in a louder ticking noise.
of course the ITR spring type lma's is the answer, but they're pricey
ps: didnt listen to your vid as im at work, and re-read your original post. if youre gettin a ticking noise while cranking the starter, id look elsewhere.
S1000RR
Dec 5, 2012 11:01 PM
92Eg6B18b
10
Nov 30, 2008 12:50 AM
Danjal
Nov 27, 2008 11:51 AM
Jintegra99
May 14, 2004 07:05 PM
