96 civic ex speedometer only works when flooring the gas, Help
I have a 96 ex, , lsvtec, type r tranny. Tried 3 known good clusters, speedo will ONLY work when I nail on the car and get some wheel spin in first gear, I know it's odd. any ideas? As soon as i step on it , it works for a second then goes back to nothing, It only works when the wheels spin really fast
That's what im gunna do here as soon as i get a chance, it almost has to be the sensor
Im almost thinking the gear is the issue, I have tried 3 clusters , All of which worked fine before. Unless there is a wiring issue somewhere it almost has to be the gear, I guess im gunna have to pull the VSS and take a look
A wiring issue would throw a code, unless there's a poor connection between the VSS wire terminal in the cluster connector and the cluster. Start by removing and inspecting the VSS.
