Broken Stud on Firewall
I broke the stud that connects the water valve to the firewall. Does this unscrew from the firewall? It looks like it might because of the washer looking piece at its base.
I had the heater box out. The is a gap between the firewall and the inside of the car because I cannot see anything on he other side. There are spot welds that I can see on the firewall but they are about 1/8 inch around the edges of that head so I don't think that head is spot welded. I wanted to know before I did some damage trying to remove it.
as i posted before and i have done a shave cutting and grinding them all off
all of those studs are welded on
there is only one stud that comes through the fire wall that supports the heater box and its got a 8mm nut on it
and is lower down than the heater tap stud and closer to the middle of the firewall
dont forget some places on the firewall are double skinned and you wont see everything
Is there some way that I can subscribe to a thread so that I don't have to look for it in the list of threads every time I want to see if someone replied.
OP, it sounds like you can drill out the broken stud and install a bolt.
C4st0r_Tr0y
Jan 13, 2007 05:52 PM
