98 Civic B20/VTec not starting
Old Jun 4, 2012 | 03:58 PM
mattman9305's Avatar
Icon6 98 Civic B20/VTec not starting
Hey guys, I'm new here but I have a problem with my Civic. I am having trouble starting it after running a while. Sometimes it will start and have a rough idle until it warms up, other times it will just sit and crank forever. I took the computer out and unplugged it and sprayed electrical cleaner in the ports and the pins, thinking there was corrosion, which there was a little. Then it started fine. No rough idle or anything. Then I ran it for about 70 miles with multiple start ups and then it wouldn't start. I unplugged and plugged back in the computer and it starts fine. Someone please help!!!
Old Jun 4, 2012 | 04:16 PM
grumblemarc's Avatar
The Grumpiest
Default Re: 98 Civic B20/VTec not starting
Sounds like your ECU or the harness.
Old Jun 4, 2012 | 04:40 PM
It has a chipped OBD1 ECU I believe out of a 5th gen Civic. And I tried the original ECU and had the same problem
Old Jun 4, 2012 | 05:32 PM
The Grumpiest
The harness then. Whether it's chipped or not makes no difference at this point. Check the main relay while you're at it. If you're throwing any CELS post those as well.
Old Jun 4, 2012 | 09:12 PM
No, no CELs its just a cheap ebay harness. What brand do you recomend?
Old Jun 6, 2012 | 02:27 AM
bump
tim8780
29
Jan 11, 2017 02:33 AM
joeyburke3
Feb 8, 2016 03:53 PM
jgwaja
Jul 13, 2015 02:50 PM
Ls-v Da Teggy
Aug 5, 2013 11:27 PM
muhaMan
Apr 16, 2007 08:34 AM
