what do i do?!?! so much rust!
Old Jun 3, 2012 | 01:19 AM
rusty90crx's Avatar
Default what do i do?!?! so much rust!
ok so i just got this car for free (got a datsun for free and traded it) so k rusted the whole car not my style anyone got any ideas to fix rust so i can paint with rustolium white
Old Jun 3, 2012 | 01:23 AM
Swap'DShuttle's Avatar
Default Re: what do i do?!?! so much rust!
Iron paint or did the tard let it actually rust?
Old Jun 3, 2012 | 01:24 AM
Dc4LsTeG's Avatar
EK9
Get a new car?
Old Jun 3, 2012 | 03:43 AM
rusty90crx's Avatar
its surface rust they sprayed it with unicorn **** and im not getting a new car this is what i got and i need to make it work
Old Jun 3, 2012 | 04:27 AM
wanabebuff's Avatar
That's more than likely just surface rust, if its not pitted too bad, you should be able to sand it off. As soon as you get it sanded, get some good primer on there so it doesn't rust again.
Old Jun 3, 2012 | 04:30 AM
Bobalobagis's Avatar
To be honest It's going to be hard to remove and time consuming. If u have air get you a DA and finer grit paper as all you want to do is knock off the rust. Something like 320 should be fine enough with out removing to much metal. Would even give you a good tooth for paint.
Old Jun 3, 2012 | 01:14 PM
rusty90crx's Avatar
Thanks and also does anyone sell half radiators for efs
Old Jun 3, 2012 | 01:21 PM
Nooch's Avatar
Yes, all over craigsbay. Also you can make them fit from other models (eg, ek, etc.)
Old Jun 3, 2012 | 02:04 PM
Good luck! Get air tools!
ampm
Paint and Body
May 2, 2007 05:16 PM
HamiltonRex
16
Aug 9, 2006 05:19 PM
-Gambit-
Dec 12, 2005 12:37 PM
fcuked
43
Mar 21, 2003 03:55 AM
Leb_CRX
Aug 13, 2002 08:44 AM
