2000 ITR o2 sensor check engine
Old Jun 2, 2012 | 06:50 PM
Rightside's Avatar
Default 2000 ITR o2 sensor check engine
Hey guys I looked but couldnt find anything I just bought a 2000 black ITR and it was throwing a code which said it was the bank one sensor one o2 sensor so I replaced the sensor before the cat and reset everything and it stayed off for about 30 seconds and came right back on throwing the same code.
Any words of advice
Old Jun 2, 2012 | 07:15 PM
siguy9900's Avatar
Default Re: 2000 ITR o2 sensor check engine
Check the harness for any broken wires. Its kind of a pain. You can test the resistance on the old sensor to see if it was even really bad.
My .02
d=f20c1's Avatar
did you buy a bosch sensor? or did you buy and OEM replacement?
Bosch sensors suck and that tends to happen.
Old Jun 2, 2012 | 09:37 PM
siguy9900's Avatar
Yeah, stay away from a Bosch.
Old Jun 3, 2012 | 09:29 AM
Rightside's Avatar
on the old one there were some wires that were frayed so i understand why it was throwing the code and yes i did buy a bosch so looks like i will be replacing it with an oem one.
Old Jun 4, 2012 | 09:03 AM
94eg!'s Avatar
#1 Super Guy
Loved
Denso makes the OEM sensors. You can buy the OEM sensor in a Denso box with the connector for something like $40. Only difference is the wire color on two wires. Check google for current pricing.
You can also buy the same sensor in universal form and simply splice the 4 wires into the old pig-tail. The wire colors are different, but it's not hard if you follow the instructions. I thin you can get the universal/splice sensor for $30.
Direct fit:
- upstream 234-4011
- downstream 234-4659
Universal:
- both 234-4209
OogalyDoogaly
19
Apr 20, 2021 11:40 AM
Nando613
Honda Civic (2001 - 2005)
Mar 29, 2015 05:38 PM
vrotsos991
13
Nov 14, 2011 06:31 AM
killer6993
10
May 23, 2005 09:45 AM
eTec
May 31, 2002 08:50 PM
