what code is this?
Old Jun 2, 2012 | 07:05 AM
m3kid's Avatar
Default what code is this?
ok im not getting any spark did a dpfi to mpfi obd1 mini me swap using a jumper harness and a p06 ecu for now. I thought it was a code 10 but i got the iat sensor hooked up with the right color wires so what code is this? thanks
http://s468.photobucket.com/albums/r...t=HPIM3460.mp4
Old Jun 2, 2012 | 08:31 AM
Goinhamindatrap's Avatar
Default Re: what code is this?
Check your timing and distributor, maybe you put it on backwards.
Old Jun 2, 2012 | 08:33 AM
m3kid's Avatar
put the distributor backwards? and timing was set all on tdc. What code is this?
Old Jun 2, 2012 | 10:20 AM
civickiller's Avatar
code 10 i thought you had it fixed, just because you change the sensor doesnt mean it was the sensor
but lets see what others say
Old Jun 2, 2012 | 11:47 AM
m3kid's Avatar
nahh i didnt change the sensor i just had the wrong plug in the wrong place but i will try to replace the sensor. But i just cant figure out why im not getting spark?
killafred187
Aug 12, 2011 05:15 PM
TyeJ23
Nov 7, 2005 01:42 PM
jdmazm
Apr 24, 2005 04:34 PM
Civic Racer X 7
Aug 4, 2003 10:50 AM
