Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
2005 Acura TL hard to start!
Old Jun 1, 2012 | 04:10 PM
kct01's Avatar
Default 2005 Acura TL hard to start!
The wifey calls me today at 5pm, right after work and says shes stuck at work and the car won't start and is weak when it she trys to start it up.
I arrived at her work and tried to crank the car up. When I try to crank it up and strong cranking at first and then cranking get weaker with each attempt. All lights and everything works fine.. If I wait 10 seconds and try again, it repeats this identical: "strong cranking and then cranking get weaker with each attempt, then nothing at all with key turned all the way to start"
The car never showed any signs or symptoms and it was fine just yesterday and this morning when I ask her.
I have a big feel it's the alternator???
Old Jun 1, 2012 | 07:24 PM
Flat-bedded05's Avatar
Default Re: 2005 Acura TL hard to start!
Load test the battery, then make sure the alternator putting out 14 to 14.5. Just by what your describing its the battery.
Old Jun 2, 2012 | 07:30 AM
kct01's Avatar
what would be the symptoms of a bad alternator?
Old Jun 2, 2012 | 11:05 AM
kct01's Avatar
Stupid NAPA battery!!!!! Thanks for the input Flat-Bed!
NiKKa NiKKy
Jun 30, 2022 09:59 PM
swizz977
23
May 6, 2011 04:01 PM
TOO MUCH TORQUE
Dec 18, 2009 12:30 PM
hackykid
Aug 8, 2007 11:16 PM
SOKDO
Jun 2, 2005 10:33 AM
