RC 750cc Injector help!?
Old Jun 1, 2012 | 01:21 PM
Bobalobagis's Avatar
Default RC 750cc Injector help!?
Sat down to install my rc injectors and came across a problem. Pics to follow.
If you look at the difference there is a ridge on the stock injector. The o-ring sets up against that ridge at the bottom of the injector. The RC injector do not have that ridge at the bottom. As a result of it not having the ridge it will not allow the injector to set all the way into the intake manifold. On to the pics.
My question is, is this ok or not? The injector is tight and looks OK. But i wanted to make sure before i start this build any further.
Old Jun 1, 2012 | 04:20 PM
Default Re: RC 750cc Injector help!?
Bumping ttt. Wanting to get the motor assembled tonight. But don't want to go any further till I get this sorted out.
Old Jun 2, 2012 | 04:36 AM
non-VTEC's Avatar
i do think that's how they fit....the cushion seals don't fit in the same location as the OEM injectors....they just kinda squish over top of the fat end of the RC injector...just make sure the fuel rail tightens down ontop of the injector and there is no gap.
Old Jun 2, 2012 | 04:39 AM
grumblemarc's Avatar
The Grumpiest
Install them. Check for any vacuum leaks afterwards.
Old Jun 2, 2012 | 05:29 AM
Thanks for the help. They are tight and don't seem to leak but I will find out for sure when I get the block assembled and running.
imationdawg
Aug 1, 2009 07:33 AM
valleyhatch
Mar 27, 2008 01:26 PM
donut.
48
Mar 21, 2008 06:26 AM
infumis
Feb 8, 2007 03:46 PM
sneakypete
Jan 31, 2004 10:39 AM
