obd1 to obd2 question
I have a 97 gsr shell and I am planning on dropping a obd1 ls in it. My question is will everything from the obd1 just drop in and I just use a obd1 to obd2 jumper harness for ecu or will I need to replace injectors,intake manifold,dizzy?
Pay no attention to speedJUNKIE g35 he sell's Google.com stickers for a living.
https://honda-tech.com/forums/hybrid-engine-swaps-18/%2A-%2A-obd1-b-series-engine-into-obd2a-obd2b-civic-integra-%2A-%2A-1972711/
yes the engine has wiring harness and all the sensors, can I just drop it in and everything will plug n play? I know the dizzy is at least different,can I use my obd2 gsr dizzy? The obd1 ls was from a automatic and has a egr valve should I just use a obd2 intake manifold and everything else should plug n play without any mods
I am in the middle of putting 99ls ecu and intake manifold, distributor obd2, evap canister injectors, etc on a b18b1 ls motor out of a 95 integra, so i can put it in a 96ls integra. I was told that i would have to change all that over in order for it to smog
I don't think you'll pass with an older engine in a newer shell. I could be wrong but CA has some pretty strict rules
NOman0608
Jul 26, 2007 10:28 AM
HmgLauj69
10
Aug 11, 2005 05:27 PM
