How in the world do I wire a cx engine harness for vtec?
Old Oct 14, 2002 | 01:49 AM
Touch's Avatar
Default How in the world do I wire a cx engine harness for vtec?
You guys told me I could do it, so now I deed to know how.
Please help Asap. I would appreciate as much detail as possible.
Pics welcome.
For guilt purposes:
Without your help I just got a SOHC paperweight.
Thanks
Old Oct 14, 2002 | 04:34 AM
TodaSi's Avatar
Default Re: How in the world do I wire a cx engine harness for vtec? (Touch)
SOHC VTEC in a CX? Or DOHC VTEC in CX?
DOHC VTEC, get a GS-R engine harness, I was gonna re-wire mine but it was a nightmare, so I just bought a GS-R engine harness and plugged it up.
Sorry can't hepl with a SOHC VTEC.
[Modified by TodaSi, 8:35 AM 10/14/2002]
Old Oct 14, 2002 | 07:31 AM
Touch's Avatar
Default Re: How in the world do I wire a cx engine harness for vtec? (TodaSi)
yeah it's SOHC
Old Oct 14, 2002 | 05:43 PM
kinesistech's Avatar
obd1 or 2?
Old Oct 14, 2002 | 06:24 PM
poison's Avatar
For any VTEC ECU...
you add wire to VTEC oil pressure sensor for ground (tap into Grn/Wht wire), ECU Signal (splice into Blu/Blk wire from firewall which leads to D6 pin-out on ECU) and VTEC solenoid valve to ECU (tap into Grn/Yel wire from firewall which leads to A4 pin-out on ECU)
that's it
Old Oct 15, 2002 | 09:19 AM
Touch's Avatar
Default Re: How in the world do I wire a cx engine harness for vtec? (poison)
For any VTEC ECU...
that's it
thanks Poison,
but the car is already wired for vtec, and the ecu is the correct ecu for the motor,
The problem is: the actual plugs on the motor need to be wired for vtec. Again, I'm tryin to use my old cx engine wiring harness, and wire it for the vtec in the jdm d15b motor and connect it to the jdm motor.
Old Oct 21, 2002 | 07:09 AM
EG6owner-T's Avatar
dont the cx harness have the 1 wire O2 sensor?
Old Oct 21, 2002 | 08:30 AM
poison's Avatar
Default Re: How in the world do I wire a cx engine harness for vtec? (EG6owner)
thanks Poison,
ya, you can use it from the jdm d15b wiring harness and add it to the stock cx harness, and plug them into the spool solenoid as well as the oil pressure and wire it to the shock tower.
ya, they are 1 wire o2 sensor.
Old Oct 21, 2002 | 10:34 AM
EG6owner-T's Avatar
is there a way to put the 4 wire on?
Old Oct 21, 2002 | 10:39 AM
badCRX's Avatar
New User
yup, I just wired one up last night.
Old Oct 21, 2002 | 11:07 AM
EG6owner-T's Avatar
Default Re: How in the world do I wire a cx engine harness for vtec? (badCRX)
can you help me out with my 93 cx then?
Old Feb 11, 2003 | 08:23 AM
Fuster_Cluck's Avatar
DOHC VTEC, get a GS-R engine harness, I was gonna re-wire mine but it was a nightmare, so I just bought a GS-R engine harness and plugged it up. <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0">
Does this go for a OBD2 GSR motor in a 93 Cx as (Canada model) as well?
I heard it's just 4 wires I have to run for the Vtec or I can buy a Vtec harness which I was told is over $100. My motor should ship out today or tommorrow and I need to figure out what way I should go. Thanks!
Old Feb 11, 2003 | 10:29 AM
Lysawy's Avatar
Default Re: How in the world do I wire a cx engine harness for vtec? (Hybrid93Hatch)
damn everyone makes problems and noise about adding wires its only few of them....
streetracerof06
Nov 9, 2005 02:30 PM
Touch
Feb 11, 2003 08:28 AM
FUP23
Feb 24, 2002 04:35 AM
