Y8 head on Z6 block!!!!!
Old Oct 14, 2002 | 01:21 AM
burnicq's Avatar
Default Y8 head on Z6 block!!!!!
I was wondering if anyone knew if you could put the Y8 head on a Z6 block. If so could someone give me the torque specs on the head bolts and does anyone know or have a diagram of how to line the head up with the block , so that they are in the correct timing order. If you could email me with the info that would be great.
burnicq@attbi.com
Thanks
Old Oct 14, 2002 | 05:13 AM
teal_dx's Avatar
Default Re: Y8 head on Z6 block!!!!! (burnicq)
this swap is possible, I just put a Y8 head on a D15b7. For the timing just be sure that u use the TDC mark and the head bolt torque you can get from a helms, I used 53 ft/lb. as far as the exact specifications for your swap, I cant help you there.... do a couple searches and you should find some info
Old Oct 14, 2002 | 06:34 AM
GasHuffer's Avatar
Default Re: Y8 head on Z6 block!!!!! (teal_dx)
what is the advantages of this swap?
Old Oct 14, 2002 | 07:00 AM
teal_dx's Avatar
Default Re: Y8 head on Z6 block!!!!! (GasHuffer)
the Y8 head will give higher compression 11:1, so if you plan on going turbo then I'd stick with Z6 head.
straightshot08
Nov 9, 2009 01:59 PM
Nichelson_Performance
Feb 3, 2009 10:07 PM
91dxhatchswaped
15
Jul 20, 2004 08:55 PM
.Beaver
Aug 12, 2003 05:46 PM
4gvtec
Sep 15, 2002 10:36 PM
