Stuck Oil Pan bolt
Old May 31, 2012 | 12:41 PM
KYDelSol's Avatar
Default Stuck Oil Pan bolt
I was trying to change a leaky oil pan gasket on Gsr in my Del Sol and I can't get the nut off two of the threaded studs that come out of the bottom end. They are the ones near the flywheel. I can just spin both of them. They don't get tight or fall off the stud. They are loose but I can't get the nut to come off. I have tried vise-grips with no luck. Any idea how to get these nuts off or anyone had this problem before. I can upload a picture when I get off work if needed. Thanks if anyone can help!
Old May 31, 2012 | 12:45 PM
Dc4LsTeG's Avatar
EK9
Default Re: Stuck Oil Pan bolt
Impact gun or cut it off either way your going to have to replace the stud and nut
Old May 31, 2012 | 12:49 PM
KYDelSol's Avatar
How hard is it to replace the stud? Does it just bolt in like the ones on the valve cover?
Old May 31, 2012 | 12:57 PM
Dc4LsTeG's Avatar
EK9
Yea it just threads into the block
boostin1!
Oct 13, 2013 08:44 AM
TahitianEG
Sep 5, 2006 09:41 AM
Monkey Fing a Coconut
Apr 20, 2005 01:10 PM
SdGSR01
Sep 8, 2004 04:24 PM
linx
Jun 16, 2003 01:29 PM
