Type R cams on Stock GSR
Old May 30, 2012 | 08:30 PM
jeresaur's Avatar
Default Type R cams on Stock GSR
ive looked all over the forums and cant find a straight answer... BUT ima shoot for it. I was reading that the gsr cam (ex) is like the type r (int) and so are the internals i guess......? (but cam for sure). so if i wanted to know if i could run that set up with 1 cam or should i just go out and buy both.???? either way ima get a tune and IM...sooooooo
thanks for the help
Old May 30, 2012 | 08:33 PM
doood's Avatar
been there done that
Default Re: Type R cams on Stock GSR
you're not very good at searching. found this in 2 seconds through google: https://honda-tech.com/forums/tech-misc-15/b-series-cam-spec-list-specs-all-%401mm-388612/
Old May 31, 2012 | 09:53 AM
SuzukaBlueS2K's Avatar
Originally Posted by doood
you're not very good at searching. found this in 2 seconds through google: https://honda-tech.com/forums/showthread.php?t=388612
Huh...they are similar, if you are to trust that information...not saying it's wrong, just saying it's from some dude on the internet.
Old May 31, 2012 | 10:44 AM
doood's Avatar
it's not like you can put an intake cam on the exhaust side anyway
Old May 31, 2012 | 04:12 PM
jeresaur's Avatar
ohhh yeah i meant the valve train...the geezrs intake springs are the same as itr springs right? so all i need would be the itr cams, itr valve springs(intake only), and maybe a IM..then tune... if i switch to that set up would i have to run retainers?? tryin to keep the cost low .....
Old Jun 1, 2012 | 09:33 AM
usdm420's Avatar
816d16 owes me money!
Community Builder
Community Influencer
Active Streak: 30 Days
If you are going to keep the factory redline, there really is no need to swap out your valvetrain. 8k rpms is 8k rpms.
Old Jun 1, 2012 | 10:24 AM
racebum's Avatar
R cams have more lift and should be using more spring. guys do get away with the gsr vt if the redline stays the same, but, if you change cams you'll be doing a tune anyway.
long story short with a gsr is
1. do a header and nice air filter
2. boost it
3. tear it down and do a build with more compression, cams, ported head etc
randomly changing parts isn't going to do a whole lot. R cams on a stock gsr are worth 5-7hp. that's it, that's all
Old Jun 1, 2012 | 10:29 AM
usdm420's Avatar
Community Builder
People run ITR cams in stock GSR/B16's all the time with zero issues. Like I said, waste of time and $$$ IMO if you're not going past stock redline.
But I do agree that really even adding those cams isn't worth the hassle. Upgrade the valvetrain and get some stage 2 cams if you want power. But then again, you'll need to bump the compression in order to maximize those gains as well sooooooo, now you're back at square one and you might as well just boost the stock motor.
Old Jun 1, 2012 | 09:07 PM
PURPLERANGER's Avatar
Don't forget the Valvetrain upgrades, and with the bigger cams, you can make more power higher up the RPM, and rev higher, to make more power, so it wouldn't be a bad idea to get a Type-r Cluster, but you don't need one, it would just be sort of a useful novelty
racebum
Dec 7, 2007 11:12 AM
ELPITUDO
Jul 27, 2007 12:41 PM
hlee5363
Sep 26, 2005 01:25 PM
fastfu
Dec 19, 2003 03:51 PM
skunked
Dec 12, 2002 10:01 AM
