cheapest way to raise car
just got a 1995 Honda civic and the idiot before me slammed the car the is only like two inches of ground clearance got a great deal so not a big deal what would be the cheapest way to raise it it looks all stock s i don't know where to start any help would be appreciated thanks
If the PO just cut the springs, all you need is a set of OEM springs and some spring compressors. I spent 6 months trying to sell my old OEM suspension before I finally just gave it to a friend - I'm sure you can find a used OEM replacement from someone who upgraded for next to nothing either on craigslist, the HT marketplace, or regional car forums.
++ on the last four posts.
If you're just trying to bring it back to original height, get the OEM suspension pieces.
If your trim is anything other than an Si, I think these are all the same (but double check this)...
like the other peeps said.. craigslist
or hit up your local pick n pull.
either way stock suspension isnt too hard to come by for cheap, being that most tuners wanna UPgrade their setup, not DOWNgrade
Replacing cut springs with stock springs would definitely be an upgrade for the OP.
Lukvaaj
Mar 8, 2011 04:57 PM
