Fan switch temperature
Old May 29, 2012 | 04:22 PM
civicmike98's Avatar
Default Fan switch temperature
My fans consistently turn on at 208-213 degrees, the manual states they should turn on at 196-203. No idea if it's an genuine Honda sensor or not. Just wondering if anyone else has noticed the same.
Old May 29, 2012 | 04:58 PM
motegicivic's Avatar
Default Re: Fan switch temperature
What model car, auto or stick?
I think the average is about 210 which fine, as long as it comes on you are fine.
Old May 29, 2012 | 05:55 PM
EsotericImage's Avatar
Retired Moderator
210 is on the high side.
190 should be the "normal" temp
is this the oem set up or did someone use a cheap ebay fan?
Old May 30, 2012 | 12:18 AM
duh, it's my daily 99 Civic commuter, auto, all stock (unless the previous owner repaired it with the incorrect part)
Old May 30, 2012 | 12:19 AM
jbpnoman's Avatar
Originally Posted by civicmike98
duh, it's my daily 99 Civic commuter, auto.
And how exactly what anyone supposed to know that before you said it? We can't read your mind.
Old May 30, 2012 | 12:24 AM
"duh" as in "duh, that should have been in the original post"
Old May 30, 2012 | 12:31 AM
jbpnoman's Avatar
and how were we supposed to know that?
In all seriousness though, you're still within safe operating range. Most aftermarket fan switches come on sooner, not later. Yours might just be getting old. You could replace it with a factory part, but I personally wouldn't worry about it.
Old May 30, 2012 | 12:44 AM
lol, well played
Well, that's 5-17F above spec according to the service manual. FYI, I also just replaced a HG, and surprisingly enough I don't want to do it again I noticed this while bleeding the coolant. Unfortunately, "aftermarket" could also mean crappy non-oem part. Not sure if this is how these sensors start to fail, etc.
On a similar note, don't suppose anyone has actually noted at what point the oem dash temperature need actually moves? Mine doesn't budge even up to 223.
Old May 30, 2012 | 01:12 AM
siregcivic's Avatar
fan switch oem is around 210 degrees, my h22 with oem fan switch turns fan on at 210 same as my friends h22 swap civic oem fan temp switch is right around 210
f15Civic
Mar 9, 2017 05:45 AM
calrodz
10
Jan 8, 2015 06:58 PM
G. Man
Aug 28, 2011 12:21 PM
foxlinkinc
Nov 4, 2008 04:36 PM
Dunc
Sep 19, 2007 08:54 AM
