Fan switch temperature
My fans consistently turn on at 208-213 degrees, the manual states they should turn on at 196-203. No idea if it's an genuine Honda sensor or not. Just wondering if anyone else has noticed the same.
Re: Fan switch temperature
and how were we supposed to know that?
In all seriousness though, you're still within safe operating range. Most aftermarket fan switches come on sooner, not later. Yours might just be getting old. You could replace it with a factory part, but I personally wouldn't worry about it.
lol, well played
Well, that's 5-17F above spec according to the service manual. FYI, I also just replaced a HG, and surprisingly enough I don't want to do it again I noticed this while bleeding the coolant. Unfortunately, "aftermarket" could also mean crappy non-oem part. Not sure if this is how these sensors start to fail, etc.
On a similar note, don't suppose anyone has actually noted at what point the oem dash temperature need actually moves? Mine doesn't budge even up to 223.
fan switch oem is around 210 degrees, my h22 with oem fan switch turns fan on at 210 same as my friends h22 swap civic oem fan temp switch is right around 210
calrodz
10
01-08-2015 06:58 PM
foxlinkinc
11-04-2008 04:36 PM
