del sol and integra compatability
Ok so I have a b16a3 del sol and the engine harness is cut up.... Could i use the harness off a 93 integra. I found a teg on clist and was wondering if i caj use it. I know the sol harness has the ability to unplug at the firewall but could it work? Also what could I take off the integra for my sol? This is the teg. thanks http://wichitafalls.craigslist.org/pts/3045309678.html
I have no experience with OBD1 swaps, but I've done a couple OBD2 swaps. Since both cars are OBD1 the plugs should fit. You may have to extend some wires, and use plugs off the chopped harness to wire up the VTEC solenoid. But I can't give a definitive answer without having experienced it myself
Ok i do think the harness would work but idk about plugging it in since the del sol harness has the plugs on the firewall. Do you think the rims look good? I might try n snag em
94-95 integra vtec harness
92-95 civic vtec harness(sohc have to move the O2 sensor plug to the back of the engine.
93-95 del sol vtec harness same as above
firewall harness has to be from del sol
So its a no go
whatabout the rims? Id say if I get them cheap I can flip them or put them on the sol. Are the stocks from the teg or what can yall tell from the pic? Thanks guys
