new f2d write up
Old May 28, 2012 | 08:07 AM
jonina's Avatar
Default new f2d write up
i know there are not many write-ups on this swap and i just completed mine so i was woundering if anyone is interested in it. i could do a write-up on it and give every detail you will run into that the other write-ups did not write abount. so if you guys have any questions and want to see a write up with pictures let me know.
this is my first custom swap and i am not a mechanic so please excuse my mechanical vocab lol
Old May 28, 2012 | 10:31 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: new f2d write up
Yes please
Old May 28, 2012 | 02:18 PM
jonina's Avatar
Sooo, my laPtop being retarded right now and I can't upload my pix I'll try it again later tonight if not tomorrow after work
You have any quick questions I can answer meanwhile pm me
Old May 28, 2012 | 02:28 PM
thundernoodle's Avatar
no kit?
Old May 28, 2012 | 05:07 PM
jonina's Avatar
Yes, bisi f/h2d kit. Cheaper and lighter then buying/using f/h series tranny, axles and shift linkage. You also get a 8-10lbs evolution flywheel. And it is also cheaper in the long run, d-series axles can be found for $20-$30 each where as f/h cost around $100 each because they must be custom to fit civic knuckles
Old May 31, 2012 | 03:30 PM
jonina's Avatar
Hondapartshero: pm me if you want some info. on the swap
Old May 31, 2012 | 05:34 PM
TheMechanic84's Avatar
im in for a write up
Old Jun 5, 2012 | 12:07 PM
Cameron R's Avatar
Bump! Write up please.
Old Jun 16, 2012 | 09:18 PM
jonina's Avatar
sorry guys, been busy. ill start the write up on monday
Old Jun 16, 2012 | 10:41 PM
deucedeuceEK's Avatar
Some things are worth the extra money. I don't understand h2d.
Old Jun 22, 2012 | 09:40 AM
civicmule's Avatar
Id like ta ride in one
Old Jun 22, 2012 | 01:23 PM
victor.ek4's Avatar
I have an F2B sohc on my EK hatch.... I do have a spare F block and a D trans which I'm going to try to put toghether without a kit
Old Aug 27, 2012 | 08:25 PM
Vosachi's Avatar
What mounts did you use and what harness!?
Old Aug 28, 2012 | 09:41 AM
Doberio's Avatar
Icon5 Re: new f2d write up
Urggghhhh small minded!
Really, you DON'T see any advantage to using a D series tranny/axles/shift rods... Unless you already have a B-Series under the hood.
Other than the available gear ratios and equal lenght axles, the B-Series hasn't got a whole lot going for it.
On the other hand EX/Si tranny are a dime a dozen, so are the axles. The some D-Series have beefier shift forks and the JDM LSD D-Series tranny is only $400 at any importers.
I could build an awesome JDM LSD D-series tranny with some custom gears and still not even come close to the price of an OEM LSD B-Series (and you still need axles, mounts and shift rods).
F20B - $500 (in any Montreal JDM importers)
H2D - $700 (Bisi even has a special for $670)
for $1200, you have reliable swap that will keep up with a K20 and kill 99% of all stock B-series in the quarter.
H/F2D is the thinking man's kit.
Old Sep 1, 2012 | 07:58 PM
Vosachi's Avatar
Still no response on mounts/harness
Old Sep 29, 2012 | 08:04 PM
jonina's Avatar
stock mounts, just made a driverside engine bracket. tony tucks made my engine harness for $150. "in south cali"
jonina's Avatar
pm me for more info
speedfreak44
Aug 15, 2009 07:27 AM
WillSB
Dec 8, 2008 09:57 AM
nk2k2
Feb 9, 2006 04:27 PM
BuiltTurboCoupe
Sep 17, 2004 12:53 AM
Spoonedcivic
May 19, 2004 06:19 PM
