erratic idle at constant rpm's?? jdm GSR
Old May 28, 2012 | 04:20 AM
CarnageEK's Avatar
Default erratic idle at constant rpm's?? jdm GSR
what up guys, got a 96 jdm GSR in my EK and i am in the process of geting it B.A.R.'d, i have a and erratic rpm idle while the throttle is depressed and held at a constant (any) rpm, ex. 3000k it will bog down 300-500 rpm's and then slowly come back up to rpm??? checked for vacuum leaks holding a steady 20-22hg, coolant system is not air bound, new o2 sensors, no CEL, grounds are good, timing is on point to 16.?? any and all help plz
Old May 28, 2012 | 05:41 PM
TKERacer619's Avatar
Default Re: erratic idle at constant rpm's?? jdm GSR
Have you checked the air idle control on the throttle body?
Old May 29, 2012 | 02:24 PM
CarnageEK's Avatar
yes i have checked theTPS and IAC, im waiting for a fog machine to come in and im going to fog my intake manifold to see if its 100%, ***** been really bugging me im just .30 over my HC on my smog to get a b.A.R. sticker.....
Old May 29, 2012 | 03:17 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
I had the exact problem where it would fluctuate 3-400 rpm's two weeks ago and it turned out being a small crack in the vacuum tube for the fuel pressure regulator. I would double check your vacuum lines.
Old Jun 1, 2012 | 03:27 PM
CarnageEK's Avatar
Thanks bro, just got my fog machine in today from amazon, I'll give an update. It would be the only thing left. How small was it
Old Jun 1, 2012 | 07:49 PM
Less than a 1/8".
Old Jun 2, 2012 | 08:01 PM
CarnageEK's Avatar
no vaccum leak, im starting to wonder if it could be the ECU? i bought it off craigslist from some guy, he said it was a 96 gsr would the year for the ecu matter?
Old Jun 2, 2012 | 08:09 PM
CarnageEK's Avatar
trying to get this over with by the end of the month
chope045
Oct 24, 2011 04:12 PM
mister.wong
29
Mar 10, 2009 03:24 PM
xxi2icexx
Dec 9, 2008 07:48 AM
lsxtreme81
Apr 20, 2007 05:39 PM
Norcalstoppy
Oct 7, 2002 10:47 AM
