96 civic ex, speedometer not working, ideas?
Old May 27, 2012 | 04:40 PM
93grayeg's Avatar
Default 96 civic ex, speedometer not working, ideas?
Hey guys, got a 96 ex, lsvtec, type r trans. Past few days speedo has been jumping around, today it stopped working completley, all other gauges work fine, pulled the cluster everything looked fine , looked down at the vss and eveything seemed tight and connected. Any ideas? Faulty cluster? Never had this issue before. Any ideas would be great. Thanks!
Old May 27, 2012 | 05:49 PM
Jtisawesome's Avatar
Default Re: 96 civic ex, speedometer not working, ideas?
I just had this issue is your engine light on and see if cruise control works if there is no engine light then swap the cluster with a working one
Old May 27, 2012 | 06:38 PM
93grayeg's Avatar
cruise.control is removed, no cel's
Old May 27, 2012 | 07:36 PM
ek3turbo's Avatar
same problem in my car it was the plug was corroded i clean it and start working again...
Old May 27, 2012 | 07:37 PM
93grayeg's Avatar
The vss plug?
Old May 27, 2012 | 10:11 PM
ek3turbo's Avatar
yes sir the one that is conected to the sensor in the tranny and see if the speed sensor its not corroded inside too
Old May 28, 2012 | 01:26 AM
bobbysworld143's Avatar
I have the same problem and I replace the speed sensor and didnt work so i got a new cluster and that fixes the problem.
Old May 30, 2012 | 04:25 PM
93grayeg's Avatar
The speedo randomly started working again today? No idea whats going on
Old May 30, 2012 | 04:28 PM
crawfo661's Avatar
pull the vss out of the tranny and make sure there isn't broken or worn down gear teeth. you should have a cel for the speedo not working aswell
Old May 30, 2012 | 08:23 PM
93grayeg's Avatar
okay , yeah i have no cel codes at all
Old May 30, 2012 | 09:39 PM
If your cluster starts to not work again just change the cluster and it should work perfect again
Old Jun 2, 2012 | 10:50 AM
Contractorslim's Avatar
So I have a speedometer that works intermittently as well. I pulled the vss I believe it has the gear on it right? We cleaned it and checked it. No sign of wear or anything. Havent had time to go through the test procedure found in a repair manual yet. Is there anything else that could be wrong? Not sure where I would find a cluster as no junkyards around have any 96's left. Any help would be appreciated!
Old Jun 2, 2012 | 05:27 PM
93grayeg's Avatar
I have a cluster i could sell you, I actually have 2. My issue isnt the cluster. I tried 2 different clusters and neither speedo's work.
Old Jun 2, 2012 | 08:39 PM
alil2cul4u's Avatar
How much for a cluster? I as well have been having this very problem! Is the cluster from a 95 lx the same as a 96? I have a 95 lx auto, and my speedo works when it wants but I also have a bad RPM gauge.. I have checked the VSS and it looked to be fine, the harness was not corroded and the gear inside looks fine.
Old Jun 2, 2012 | 08:57 PM
93grayeg's Avatar
I have a auto one. Yes they are the same. PM me
Old Jun 3, 2012 | 05:50 AM
How much are you selling them for? I can't pm yet but you could email me contractorslim @ gmail .com definitely interested!! Thanks
Old Jun 3, 2012 | 05:03 PM
93grayeg's Avatar
Okay guys i tried 3 different clusters, still nothing, also no CEL. When I stomp on the car in first and get some wheel spin the speedo will shoot up quick , ANY ideas?
Old Feb 27, 2017 | 06:54 PM
Ricky Vessella's Avatar
Hi guys I have to same problem too!?, I have an Ex 4dr and suddenly the speedo just stopped working? And the check engine light came on. The tach works, the engine works(never stopped) no burnt smells or smoke, cluster lights work, fuel gauge works...
What should I check, clean, repair or replace?
Thank you...
Old Feb 28, 2017 | 09:38 AM
Badcopyinc's Avatar
Speedo not working is either speed sensor, wires/traces corroding or stepper motors on the cluster itself.
smartest option is to troubleshoot like the thread starter was doing. physically check the speed sensor. then meter the VSS wire for your cluster see if you're getting signal.
then if you are and all checks out either replace with junkyard cluster. or send out to a repair center.
Old Feb 28, 2017 | 11:36 AM
civic402lx's Avatar
Pull the code
Old Feb 28, 2017 | 11:46 AM
CX-Adam's Avatar
talks to himself
Community Builder
Community Influencer
Thank you...
Don't bump old threads. Start your own.
What year is your car. Do you have a multimeter? Check your fuses under your dash. I don't remember the number but it's either 10amp or 15 amp fuse. Do your odometer and trip meter work?
Old Feb 28, 2017 | 01:33 PM
mk378's Avatar
Sounds a lot like fuse 15. Wires behind the engine short out and cause one or all of these symptoms:
Fuse 15 under the dash (7.5 amps) is blown.
Speedometer stays at zero, odometer does not roll.
CEL on with codes for VSS, both O2 sensor heaters, and purge solenoid.
Varying output from alternator (lights may flicker).
Civicthusiast
Feb 17, 2009 08:30 PM
JOSHGLISSEN
Aug 29, 2008 10:16 AM
chipdogg
11
Oct 25, 2006 08:18 PM
NA95d16z6
Feb 25, 2005 01:55 PM
hondaracing1
Oct 23, 2004 11:20 AM
