Clutch pedal stuck on floor, already replaced slave...
1994 Acura Integra LS 5 Speed
So i did my research, most people said to replace slave, then master.
My old slave was def. bad, it was quite torn, my master seems to be fine, no leaks or anything.
I bled the system, the clutch sinks all the way to the car floor with a slight tap, and with a slight tap under it, it then kicks back up, i may post a video because idk how describe with words.
Maybe its the spring in the clutch assembly? I looked everywhere, where do you buy them?
Also, the DC2 94 Integra has a hydraulic clutch right?
Ill post video soon.
I didnt notice any leaks, we set things under the car to detect any leaks... no luck.
And no bubbles in the system.
Here is video:
http://www.youtube.com/watch?v=IzcZ8...ature=youtu.be
Here is video:
DewtheDu88
Feb 8, 2006 05:56 PM
