What's the problems?!
Old May 27, 2012 | 12:32 PM
Pizoxic's Avatar
Default What's the problems?!
Can anybody tell me why my car starts and sounds like this? I'm struggling finding where the problems are. It's pain in the ***. Don't mind me cause I'm a noob and it's my first car.
It starts, but dies on it's own. click to watch the vid below. Thanks.
Old May 27, 2012 | 02:00 PM
civickiller's Avatar
Default Re: What's the problems?!
iacv not plugged in or switched with iat
Old May 27, 2012 | 02:01 PM
Pizoxic's Avatar
IACV and IAT... what is that?
Old May 27, 2012 | 02:39 PM
iat=intake air temperature #2 cylinder intake runner red/ylw and grn/wht or blk
iacv= idle air control valve, sensor on back of manifold blu and yel blk
Old May 27, 2012 | 08:52 PM
Pizoxic's Avatar
iacv= idle air control valve, sensor on back of manifold blu/yel blk
THANKS!!! but now when I tried to shift first gear and press the gas. The car stopped.
Old May 28, 2012 | 11:32 AM
what do you mean car stopped ? need scenario
Old Jun 4, 2012 | 12:10 PM
Pizoxic's Avatar
It's like when I'm driving on the freeway. When I rev up to engage my vtec mode, but the car iself shuts down on it's own. Does that over and over.
Old Jun 4, 2012 | 01:02 PM
grumblemarc's Avatar
The Grumpiest
Are you throwing any check engine lights? Please describe what has been done with this car that you are at this point.
Old Jun 4, 2012 | 03:55 PM
TunerN00b's Avatar
vtec mode? How is it a mode?
Looks like an Integra dash, but if so, you don't have vtec based off the redline.
Shuts down on it's own over and over? How does it shut down more than once? And what is shutting down?
If you mean that the engine dies, or cuts out, or something similar, then try actually being descriptive.
And, as grumblemarc says, post up the CEL codes the car is throwing.
Old Jun 4, 2012 | 04:18 PM
Originally Posted by TunerN00b
vtec mode?
what????
Old Jun 4, 2012 | 04:41 PM
The Grumpiest
Dash=cluster.
Old Jun 4, 2012 | 05:23 PM
fcm's Avatar
fcm
Old Fart
The vtec VC gives it away, I'm guessing swap. 94
Old Jun 5, 2012 | 12:35 AM
i dont think TunerN00b saw the video, he thought it was just a pic im guessing, hopefully
i think he means it falls on face not stops
what ecu? im thinking not enough fuel
Old Jun 5, 2012 | 10:13 AM
TunerN00b's Avatar
Correct. Thought it was just pics.
Carry on. I'll shut up now.
Old Jun 11, 2012 | 09:13 AM
Pizoxic's Avatar
code 7: throttle angel code
code 30: tcm signal
code 21: v-tec solenoid valve
code 22: vtec oil pressure switch
code 30: not sure what that is...
code: abs sensors, but I deleted abs. Will figure that out.
Don't see how any of this codes cause my car to shuts down (off) when I rev up the car on the freeway. Having hard time to start the car.
Old Jun 11, 2012 | 10:34 AM
what were the onset of these codes? thats a bunch of codes for a all of a sudden thing
code 7 is tps
code 30 is auto code
try put power(battery volts) to the vtec solenoid and see if you hear it click
code 7 might cause it to shut off
what ecu?
Old Jun 14, 2012 | 09:16 PM
Pizoxic's Avatar
code 7 is tps
what ecu?
That's what I thought. Too many codes throwing. I'm gon fix the tps and see how it goes when I drive it.
code 30 - auto code: what does that means?
ECU is p28
Old Jun 15, 2012 | 04:50 PM
saminc's Avatar
Icon2 Re: What's the problems?!
[QUOTE=TunerN00b;47444766]Correct. Thought it was just pics.
Carry on. I'll shut up now.[/QUOTE
i have a loud clicking noise on the pasengers side of my 1991 honda accord and my ANTI-LOCK light stays on. i've had no luck finding out where it's coming from, because when ther car stops, the clicking stops. PLEASE HELP!!
Old Jun 15, 2012 | 10:09 PM
ECU is p28
was the ecu an auto converted to manual?h
does the code on the side of the ecu end in p28-Axx with one of the x's being a 5
ej63_civic
Aug 28, 2008 08:04 PM
Ritter57
May 25, 2008 10:01 AM
prosumer81
Dec 30, 2007 08:51 AM
rudeman85
Oct 29, 2004 12:29 PM
jaycapz
Sep 24, 2004 08:12 PM
