B16a not running right Help!!
ok so i have a JDM B16a (OBD1) in my 95 hatch. when it is cold it idles high and fluctuates between 1200-1500 rpm. when i warms up it will try to die but if i keep reving it it weill eventually hold an idle at 900 rpm. i just replaces the distributor cap, ignition wires, rotor, plugs. and i already took apart the FITV and it was completly unscrewed so i cleaned it a screwed it in all the way. and i cleaned the IACV too. the car runs rich. it has a kenjis ecu and it has cel codes 91 and 51. what can i do to fix it?
here is a vid of it idleing cold and then warm
cold
http://www.flickr.com/photos/69121561@N02/6841559554/
warm
http://www.flickr.com/photos/6912156...in/photostream
cold
warm
ok well maby the cel wasnt hooked up to flash it was proabably the srs light. i didnt do the swap. plus my cel light just turns off when i check for it with the paper clip. but this is beside the point. could this be a map sensor problem?
tksavestheday
Jan 1, 2007 11:29 PM
