Transmission & Drivetrain Gearboxes, Differentials, Clutches
b series tranny main shaft won't spin with bellhousing bolts on
Old May 26, 2012 | 05:29 AM
mattsir1999's Avatar
Default b series tranny main shaft won't spin with bellhousing bolts on
ive realy got a bad time with my tranny at this point i dont no what to do ... main shaft spines perfectly with no bolts on the bell housing but the second i put two bolts out there it stops turning and yes i tried shifting gears doesn't help
Old May 26, 2012 | 05:43 AM
Default Re: b series tranny main shaft won't spin with bellhousing bolts on
somebody help
Old May 28, 2012 | 06:30 PM
david974's Avatar
why did you open your gear box?
incorrect 72mm shim thikness
or something is not at the right place
recheck every thing
Old May 28, 2012 | 09:45 PM
Mista Bone's Avatar
D Tranny Guru
unless something is wrong on the mainshaft or you changed gears on the mainshaft, you could have jammed the shift change assembly.
I just did this myself on a B tranny, still haven't gotten it figured out. The shafts now spin and I can find some gears, but not all 6 of them.
Old May 29, 2012 | 04:54 AM
Clerique's Avatar
I got that with a bent mainshaft recently.
Also, if two gears are engaged at the same time, it will lock up as well.
Make sure the case goes on easily and not with force.
Old May 29, 2012 | 06:43 AM
SlaminSohCivic's Avatar
put the shaft washer in because if not the gears wont line up right
Old May 29, 2012 | 03:32 PM
Gearspeed-Performance's Avatar
Your going to have to isolate your problem. To rule out the mainshaft having any bind. Remove the differential, countshaft and forks. Install the mainshaft and close the case. Does the mainshaft still lock up? If yes...then you have a problem with your mainshaft assembly. If it spins then you move on to the countershaft and so forth. Process of elimination Give that a shot and let us know what you find!
Old May 29, 2012 | 06:52 PM
ENDLESS-eg's Avatar
make sure that the top ring on the casing is opened and snapped on when the casing havles are put together and if you can find some gears the shifter plate might be bent a little!
Old Oct 9, 2012 | 10:22 PM
Em1SlowTec's Avatar
did you ever figure it out? im having the same problem.
Old Oct 10, 2012 | 06:22 AM
Honda Bull's Avatar
If the shaft doesn't spin, 95 times out of 100, it is incorrect assembly. No one online will be able to tell you what you did wrong. You will have to go back over everything or send it to someone who knows their stuff.
Old Oct 11, 2012 | 02:06 PM
chilango2004's Avatar
it happen to me once,like Honda bull said 95 times out of 100, it is incorrect assembly , I think i put 4th gear or sleeve backwards after i recheck everything that solve my problem.
FishaCrx
Dec 31, 2010 01:42 AM
odidipissuoff
Mar 16, 2010 06:45 PM
Riceboy891
Oct 31, 2008 10:18 AM
brokeHonda
Apr 27, 2006 08:50 PM
Lmgrcivic
Oct 10, 2005 07:43 AM
