Hatchback & Coupe oem fuel / brake lines?
Quick question. Have a junk 92-95 coupe and WANT to use all brake/fuel lines on my 93 Hatch. Both are drums in rear and non abs. Both Dx i believe.
Are these lines interchangable?
I can't speak with 100% certainty but you should be able to, depends on which lines. If you have a question about a particular line, you can check parts diagrams online at hondaautomotiveparts.com or parts.sonshonda.com sonshonda is better for comparison as far as what fits what IMO. I've used coupe rear trailing arms to swap to a hatch, and so it seems to me that the hardlines would be the same, but I believe ebrake cables may differ.
Wrong. Coupe/sedan are the same. I'm running all hardlines from a '93 coupe on my '94 sedan right now. Hatch I'm not sure about, they may be slightly shorter. Also '95 only civics have a different fuel feed line than '92 - '94 Civics, this means the fuel filter and bracket must be for the same year as the lines.
Some part numbers on sonshonda are the same for coupe/hatch.
I would say so. The hatch wheelbase is a little shorter than coupe/sedan. I just checked the part numbers on a brake line that runs back from the prop valve to the right rear wheel. They're different between coupe and hatch.
Kinda of sucks because I just remembered I have a set of rust free fuel and brake lines off a '95 coupe and I need a set of lines for my '93 Si hatch.
Let me know what you find. I have found part numbers for both the coupe and hatch to be similar, but hatch having a couple part numbers that are different. I tried sonshonda. 92-93-94 will have same lines, but 95 will have a different fuel filter than the earlier ones. If you can try and mock them up that would be awesome.
CX-Adam
Jan 4, 2016 05:27 AM
FF-Bee
Jun 12, 2006 11:57 AM
275Performance
Mar 8, 2003 08:47 AM
thanks for the info man! Have you encountered this situation too?
